I just picked up the car last friday in D.C, and started to drive home. I knew that the cruise didn't work when I picked it up. I stopped at a waffle house for breakfast, and checked the fuses/vacuum lines/pedal switches, and found that the cruise clutch switch pad was missing, so taped a penny on for the time being. The light on the switch still comes on, but no joy with the cruise.
Later on, someone cut me off and when I want to honk, there was no horn either. so at the next gas stop (900 mile trip back to WI) I checked under the dash, it looked like there were some connectors unplugged, and a couple of bare spades also.
I was also told that the Airbag light has about a 50/50 chance of staying on after the car's started.
I got home, and started looking into it, and found that the green plugs are not to be connected, because they're a diagnostic connection of some sort.
BUT I've still got a couple different connectors unplugged, and some bare wire ends just hanging out.
I found that the clockspring could be the culprit. So, here's my first question: If the clockspring is broken, will the turn signals still auto-cancel? Because mine do that just fine.
And for the second question, it comes in the form of a picture:
click for full-size (4416x3312):
There's a black 6-pin connector that only has 5 pins in it. right above it are two black wires with pins that are not in any connector (I've never seen bare pins just hanging out before). and there's a 2-pin connector, towards the right of the photo, with white/black and a blue/yellow wires.
Second Question, are any of these connectors related at all to the cruise/horn and/or airbag?
I'm in the process of downloading some different FSM's to try and pore over the electrical diagrams, but if anyone knows something off the top of their head, please let me know. Thanks!
--sarge
--sarge
