81 - 100 of 386 Posts
Bluebird
Discussion Starter #81
Still need to mess with the fitment a bit, and find a decent LED resister thingy on eBay but overall very satisfied.
99 rustbox
Get a better camera instead of your 90s era KODAK disposable.... JESUS... How long did it take to process the film at wal-mart? :biglaugh:
1995 EZ30 Coupe
Hmm... seems like you cut out the slats in the center of the bumper? Looks 10x better IMO.
Do those bumpers take the same fogs as, say, an 02 outback? I've got a few spares I could toss your way, unless you're just running covers?
Anywho the car looks great, those stubby mirrors always throw me :clap:
Bluebird
Discussion Starter #86 (Edited)
Tis a good read
Thanks bruh! :sunny:
:blol: You know I'm so 90's I would though Soochie...you're so mad my car looks sexy as fuck with that bumper I can sense it through the internet!
they have a 24hr turn around I think?
:lol:
Thanks!
This bumper has been across the state of Maine, a lot of ancient GC Impreza History Channel info incoming...Benson had it on his Aspen White 2.2/2.0 turbo-frankenstein'd RS, then he either sold it to Indian Rally Rob, or Indian Rally Rob somehow acquired it through some sort of shady Rally Car type transactions. I think Dan Fuckette once owned it too (this could be #fakenews, Dan if you read this don't get pissed at me). MooseInABox aka Chris Omlette definitely once had it, because I bought it from him during a Christmas or Thanksgiving event up in The Bangor Area like 3-4 years ago. I ran it on my Acadia Green Impreza, that you sourced most of your turbo build from.
The center of the bumper section was cut out lonnnng before I aquired it (I would NEVER cut up a Version 4 bumper, that's just something my JDM pedigree wouldn't allow me to do). The bumper can theoretically take whatever fogs you can fit in there; og fluted ones, v5's, rainbow kouki's, outback, legacy, tractor supply led's, etc.
I have covers, backing plates and a set of Crystal Clears that I painted yellow with Vans JDM spray for this bumper. I doubt I'd even install or wire them up until the fall though. Like BrianOfTheJungle suggested, I should go with the multi-colored 'rainbow' kouki fogs but they're mad $$$$...even though they aren't period correct for this car they are HELLA SEXY. Look em' up, they're the sickest fog lamps for these cars.
The mirrors are just WRC replica's, but they are genuine carbon fiber and do weigh a lot less then stockers.
Bluebird
Discussion Starter #87
This has arrived, as the people cried out in joy:
Coming in at a hefty 13.5~lbs. avg... I'm not mad about the weight-I got a smoking good deal on it and combined with the Kartboy lightweight crank pulley the car will be better balanced. I considered other configurations, but preferred only lowering the weight slightly because I didn't care to change my driving habits. Mating that bad bish with ACT HDSS pressure plate and disc leftover from the green impreza.
:cool:
1995 EZ30 Coupe
I shoulda known you'd have fogs, durrr!
That's nuts, quite the life that bumper has had! Glad it didn't end up in peices in a snowbank like so many others have here in NE. I still think it looks better without the slats...:run:
I didn't think 13.5 was that heavy for a flywheel? Aren't the lightweight ones like 11.5ish? If two pounds makes that much of a difference, I'll have to reconsider trying out a lightweight crank pulley.
Bluebird
Discussion Starter #89
That's nuts, quite the life that bumper has had! Glad it didn't end up in peices in a snowbank like so many others have here in NE. I still think it looks better without the slats...<img src="http://www.rs25.com/forums/images/smilies/theyareontome.gif" border="0" alt="" title="Run" class="inlineimg" />
Ha, yeah I’ll probably still get Kouki’s if they ever go on sale.
I was just kidding about the weight of it...there’s much lighter ones available however. I decided upon this one for oem-ish street drivability, but still better rev dropping/spinning up. It’s a pretty average setup, the only harshness will be that ACT pressure plate I’m reusing (that mafucka spanks you if you don’t get it right).
Bluebird
Discussion Starter #91
Finally! Was able to pry this off the partout car, newest treat for Bluebird:
Still debating on using the leather center part.
Bluebird
Discussion Starter #93
Shwaaaaattt? Just throw it in storage in case you want to sell the wheel but NEVER use that cover. :p
I wanted to retain stock-ish look in the cabin, also I'd NEVER sell this wheel! It's a MoMo Cobra wheel from the late 80's, was used in Legacy Type-RA's.
I took advantage of the nice weather to finish up this V4 Bumper:
For comparison:
Also did the fog covers, but I am debating on using them:
<img src="http://www.rs25.com/forums/images/smilies/naughty.gif" border="0" alt="" title="Naughty" class="inlineimg" />
And this stuff ready to be installed:
Those tiny front rotors were very light, coming in at around 11 lbs. each. I also have the JDM front beam to use with the bumper, so much weight will be shaving off...
Did you use "flexible" paint on the urethane bumper? I have the same v4 bumper that's been burning a hole in my pocket! Dying to get mine put on but painting it has been holding me back. A friend was telling me I can't just rattle can it and that I need some sort of special paint for it.
Bluebird
Discussion Starter #97
I probably should have, but no I didn't. I actually did more prep work on it this time then when I had it on my Acadia Green sedan, however.
My theory is to just paint it, and put it on the car. When it chips, fades, gets otherwise fucked up etc...I'll just bring it to my paint guy and have him fix it. I'd rather have this cool bumper on with the lightweight jdm beam then not, jah feel me?
Anyway, there's a whole section on this site devoted to all things bodywork/paint that can be accessed through the search function.
:sunny:
