481 - 500 of 526 Posts
Bluebird
Discussion Starter · #481 · (Edited)
Swaybar painting:
Flooring Floor Wood Wall Shelving
"Cherry blossum red" when compared to the plastic box in the background that color just looks PINK.
Installed:
Car Wheel Tire Vehicle Automotive tire
Spherical endlinks are in:
Wheel Tire Automotive tire Motor vehicle Automotive lighting
Check the angles.
Automotive tire Motor vehicle Leg Bumper Trunk
^Axle boot is ripped, add another item to the list.
Tire Wheel Vehicle Automotive tire Hood
The angles calm down once the car is lowered off of the jacks. Test drive was fine, adjusted tire pressure and softened the damping on the coilovers. Can't wait to see how it attacks the mountain passes with an alignment and RE71-r's
Bluebird
Discussion Starter · #483 ·
Cusco Front Rad Member Brace Install:
This brace arrived in the mail:
Hand tool Gas Metalworking hand tool Bicycle part Wrench
Triangle Bicycle part Rim Carbon Composite material
^Painted it and cooked it against the fireplace.
Hood Automotive tire Motor vehicle Vehicle Car
Automotive parking light Automotive side marker light Vehicle registration plate Vehicle Grille
Rack that up to another successful install...you can just see it peeking through the bars of the grill along with the PIAA ear deafening horns.
Bluebird
Discussion Starter · #486 ·
Whiteline roll correction geometry kit installed. Still fine tuning, then off to the alignment shop to hella dial in the camber and toe. Damping adjustment of left front coilover has seized, so I will need to figure out the stroke of the right front to laterally match.
Bluebird
Discussion Starter · #487 ·
Replaced inner and outer tye dyed rods, completed string theory alignment method.
Next steps:
-New front axles
-Repair p/s rack or acquire better one
-Modify HKS Carbon Ti can to fit axleback
-Pro-level alignment
Enjoy the car!
Bluebird
Discussion Starter · #489 ·
Merry Christmas:
Speedometer Car Gear shift Vehicle Motor vehicle
300mm MoMo weighted steering wheel from 1997!
I just turned around in my driveway and the precision feel and lesser effort this provides is beyond my wildest imagination. The true test will be next year when I drive on the mountain passes by my house.
Bluebird
Discussion Starter · #490 ·
Air Duct Mod:
Temperatures were 5-7 degrees in my garage when I started-Omnitech kerosene portable heater (seen in last photo of this post) worked wonders!
Automotive lighting Hood Motor vehicle Automotive design Automotive tire
Automotive parking light Grille Automotive tire Hood Automotive lighting
Automotive parking light Car Grille Automotive lighting Motor vehicle
Car Automotive parking light Land vehicle Automotive side marker light Vehicle
Above shown:
An actual 'cold air intake'...reasoning for the lateral placement of the ducting as opposed to horizontal is for aesthetics and to hide the intake hose. Additionally, this provides for more surface area of the radiator to see air. I was going to lie, but I decided to truth instead-I used black tye-wraps to secure it.
Also finally got around to doing front axles, after stalling for far too long here they are and they look great (sure, I'll let you look at my cardboard install chart):
Light Automotive tire Gas Font Wood
Old one's were hella fucked:
Wood Metal Art Antique Bronze
Automotive tire Bumper Automotive design Automotive exterior Space
Utilized the LCA drop method (as well as unbolting the endlinks) so I can maintain my string theory alignment. Again, I turned around in my driveway and the steering feel just keeps getting crispier and toastier.
-Cusco trunk bracing arrives this month
-Still need to order a new power steering rack, any suggestions are appreciated
-Should book an alignment
-Figure out HKS Carbon Ti exhaust adapter
Bluebird
Discussion Starter · #493 ·
Cusco Trunk Brace:
Painted Aegean Blue Metallic, and hanging to dry:
Building Wood Flooring City Engineering
Installed!
Wheel Automotive tire Motor vehicle Alloy wheel Rim
Tire Automotive tire Automotive lighting Hood Vehicle
Now, I'm just waiting for my adapter to arrive to fit up the HKS Carbon Titanium exhaust. More updates to follow, based on my past journal posting experience and knowledge.
White Lwag
Not gonna lie, had a mini heart attack when I seen you painted your cusco rad brace. I've come to grips, totally dig the paint match you got goin.
Keep up the good work
Bluebird
Discussion Starter · #498 ·
What headers are on your car - are they OBX?
Straight from Chrisinabox:
"It's made by CNT (no longer makes them) and is a used copy of the one Cobb used to make. And that has been copied by OBX like 12+yrs ago."
Thanks for the kind words, Scruff. I love reading updates about your Lwag!
I painted a lot of pieces and I got dizzy from the fumes (I almost fainted). I'm not having parts be WRB when my car is ABM, I think the contrast of the blues wouldn't match. Don't get me wrong I love all variations of World Rally Blue, but I think for my build the colorway would be off. I still have to go through and repair undercarriage imperfections that got damaged from all the hard driving I put the Bluebird through over the years.
Bluebird
Discussion Starter · #499 ·
HKS Carbon Titanium exhaust install:
Tire Wheel Automotive lighting Vehicle Hood
After procrastinating installing this for soooo long I opted to retain the stock midpipe because of engine back pressure. Flange merging was interesting, utilized 2.5"--->3.0" adapter w/ crush gaskets and Ultra Black gasket sealer.
No leaks so far.
Wheel Tire Vehicle Car Automotive tire
"Hyperventilating Intensifies..."
Tire Wheel Vehicle Automotive tire Automotive lighting
Deja Vu, I've just been in this place before high R on the street...
Wheel Tire Car Automotive tail & brake light Vehicle
Looks Touge proper.
100% Mad Tight Certified fitment achieved with alternating sized urethane exhaust hangers (DO NOT TRY THIS AT HOME, I AM A PROFESSIONAL). Clearance from rear sub-frame was like totally close to a few milometers. Keys were right in it, so I fired it right up on a cold start AND it was so loud it tripped out the car alarm for my 2004 RS. 😂
I laughed out loud as I pulled it out of my garage.
Sounds ignorant and volatile, just how I remember them cannons sounding from way back when.(y)
