Anybody out there running a 42mm offset wheel? If so, what size tire are you using? I'm running a 42mm offset with 215/45 17 tires and have been getting some rubbing on the fenderlip at the very top of the arch. I have removed the rubber trim piece on the fender, and if all else fails, plan on rolling the fender lip to get the clearance. I hope to avoid the rolling.
Thanks!!
