81 - 100 of 271 Posts
99 RBP Coupe
Discussion Starter #81
i just told them i was going to bring in a set of wheels to make it easier. at the time i had said id like to do the 225/45/17, although they didnt ask for the make and model of the car. i just through out the specs i wanted and they said they could make it happen. ill let you know what they say about the 235/40/17
99 RBP Coupe
Discussion Starter #82
have more parts in and more parts will be on order. planning on getting a couple from jdm garry.
WILLLL HAVE PICTURES OF QUALITY BY THE END OF THIS WEEKEND
99 RBP Coupe
Discussion Starter #83
got some daMN pictures boys. also making progress slowly.
taking up half my uncles garage!
Debadging didnt go as planned :(
i realize that i myself need to focus on one thing at a time!
99 RBP Coupe
Discussion Starter #85
The RS steering linkage has a bad u joint so i have that on order.
I went to install radiator found i was missing a grommet: ON ORDER
I went to install throttle cable to throttle body, rs one is too short. GDB throttle cable: ON ORDER.
The parts list is growing and decaying this multi-variable function is being close to Q.E.D
AS far as whats left that i need:
GC8 Splitter for tmic
Innovate Wide band Lc-2
Openport 2.0 tactrix
Aftermarket Turbo/downpipe cover since i have invidia downpipe recommendations?
moar jdm parts
nardi wheel bruh
99 RBP Coupe
Discussion Starter #88
another arc in the build.
have to get a bench bleeder kit for the mc. also have to c clamp the clutch slave.
Oil is in
gear oil and hypoid oil is in
interior is finally in i just need to install the Lc-2 and the boost gauge correctly.
waiting on parts from subaru.
99 RBP Coupe
Discussion Starter #89
NEEDS Paint
is this for the boost gauge as far as vacuum line goes???
****ing wire fire
Reading into lc-2 set up also waiting for some last minute parts to come in.
99 RBP Coupe
Discussion Starter #92
returned the brake booster back to stock with the rs master cylinder to match it so i am able to bleed the breaks tomorrow.
finishing up replacing hoses
have a bit of tidying up to do in the bay then i can finally wire up lc-2/ boost gauge.
Builds going slow at the moment. classes started back up and im swamped: physics, calculus, engineering, chemistry is killing me
2001 2.5rs
On my car, I t'd into that same line for cruise control. It should work for a boost gauge, but my boost gauge hose is t'd onto the hose that is coming off of the bypass valve.
99 RBP Coupe
Discussion Starter #95
yeah i am going to T into the bpv hose for the boost gauge. so your saying that the T in the picture goes to boost solenoid? i thought that goes to the evap solenoid.
2001 2.5rs
that hose coming from the intake manifold goes to it. They T'd into for some reason, I did for cruise, but I don't know why they did.
Here is the breakdown I used to figure out how everything is laid out, at least for a USDM WRX 205
01 white GF
I followed you on instagram. I'm going to start a v6 sti swap soon if you want to follow back, ethansmatt
Cool seeing your build cus it's like it's a few step ahead of mine
