61 - 80 of 271 Posts
99 RBP Coupe
Discussion Starter #61 (Edited)
Timing cover cracks from shipping
oil pump leaking from jdm nagoya no big deal i jsut re sealed it
missing parts here and there i have to buy
also having fitment issues with the v7 driveline. cause gd v7 doesnt work for some reason. got an auto driveshaft
99 RBP Coupe
Discussion Starter #63
picked up an auto drive shaft and r160 diff. the r160 needs a rebuild got it for 35 bucks and 100 bucks for the driveshaft
also grabbed a 05 sti brake booster and some bushings for the steering rack
99 RBP Coupe
Discussion Starter #66
i have one front axle and two rear axles. As Far as i know they can go in either side. now as far as hubs go i sold the rear hubs. i have the front hubs but the wheel bearings are bad in them
99 RBP Coupe
Discussion Starter #67
got some things done and some things started:
removing rust and prepping for some paint to clean up the bay a little bit
got the 05 sti brake booster installed.
cut one of the studs that holds the usdm ecu in so the jdm turba one will fit.
Package came in today:
My biggest expenses left are : tires, ps lines, and fluids/gaskets/hoses
99 RBP Coupe
Discussion Starter #68
very ominous work space
started on timing today:
also resealing oil pump
my dad gave me this so im putting it in my uncles garage until i have a house of my own.
wired up for 220w and als fixed the valves from pop metal to brass.
99 RBP Coupe
Discussion Starter #69
head light fell during monsoon/microburst.
any one know where i can get glass replacement?
Paint is done doesnt match at all lololol
better than dirty ass rust
Does this gasket look good?
99 RBP Coupe
Discussion Starter #73
leak is going to be fine they take the back cap off in order to drain out all the gear oil.
also test fitted the 4eat driveshaft. looking good!! installing timing kit tomorrow as well as some bushings for the steering rack.Trying to get the tie rods on and the steering column all buttoned up. any one have pics of their dash when installing the steering column?
99 RBP Coupe
Discussion Starter #74
need to update thread with better resolution pics.
plan is to pick up an exedy hd organic clutch
also looking at bridgestone 970 all seasons for the bbs wheels.
any recommendations on tires? need a good all season for arizona occasional heat and a once a year trip to the snow.
99 RBP Coupe
Discussion Starter #75
gasket has been replaced in the rear diff. just finishing small jobs until i have the money for the clutch.
the timing belts on and also replaced the rear covers. i just need one more cover to replace along with new avcs o rings.
99 RBP Coupe
Discussion Starter #76
installed rear shifter bushing
have my mind on some tires!
switched out bad hose with good hose
got the remaining cover replacements!
Have some questions about this boost gauge i picked up, best way to install location wise? where do i even start to install this?
Correct reservoir?
Timing belts on!
99 RBP Coupe
Discussion Starter #77
picking up avcs orings tomorrow.
got an sti wang from japan in the works. its not the v5/6 its the one similar to the coupe wing but better! hahaha
ill post pics upon completion of order.
Started a new job thats full time for this semester, i only have one calculus class. so i have 2 part time and one full time job to get the bills covered and feed the machine! i get paid weekly so expect updates with parts and pics periodically faster!
have my eye on a clutch and with ot i think i ll be able to get it within my first check!
99 RBP Coupe
Discussion Starter #79
wings installed, motor is almost all the way in.
picked up cobb 3 inch cat back used locally
ordered invidia divorced cattless dp with extra bung
in works of getting the innovate lc-2 and a 3 port boost solenoid controller
pics uploaded soon. all have been iphone im looking to get some nice shots with my og cannon in the next few weeks! stay with me! were getting close people!
waiting for costco deal on tires. thinking just doing a 235/40/17 on the 04 bbs
2001 Impreza 2.5RS Sedan
Very cool. How do you handle Costco for tires? Do you just bring in the wheels and get a stock size for them? In my experience they have been picky about only doing stock sizes.
