101 - 120 of 1219 Posts
Discussion Starter #101
Ok... The heater was test fitted.
The screws were removed in favor of flush aluminium rivets..
This allows it to be mounted flat.
Discussion Starter #102
Now onto the hood latch.
Took some balls (at least for me) to cut that JDM aluminium hood.
Pin placement seemed OK but that wasn't the case..
We had to fiddle around to get it properly aligned.
Balls out.. and I cut the other latch.
Lower rad beam was removed in order to properly align the intercooler and radiator..
Up close and personal with the risers to clear the STI radiator.
Finally the seat and steering column were mounted to test the placement of the new hydraulic hand brake..
Discussion Starter #107
Rear bumper has been installed.
Few minor welds are still needed here and there but the bumper is up.
A new home for the cat... maybe muffler
2000, 2.5rs, blue ridge pearl
I'm going to order one from them after I get home from USAF basic training. Hopefully it goes smoothly... :/
Discussion Starter #109
A productive Saturday I must say...
Managed to custom mount the IC.
After 3 week wait... this beauty showed...
Raised rad supports to clear the lower outlet.
At 33" the IC was longer than expected...
Some plasma action and welding was applied.
Building a fork lift.. are we ?
Finished product... Lower IC mount brackets.
With the front bumper beam mount holes nicely boxed.
A glimpse of the Master welder.
A finished product with top support beam
Next step... Cutting the carbon bumper....
Discussion Starter #112
Lots of labor.. thats why its called labor day.
Gotta be hard work when the sparks fly out of the ass..
So much hard work that even the tow strap got welded in !!!
And a nice lightweight hand brake bracket !!!
This guy never stops!!!
The gas pedal bracket wasnt lining up.. it was cut in 1/2 and a new bracket was formed.
Since we started early today.. There was time left to trim and fit the dash.
Looking good so far.. there should be no gap.
The diet never stops...
Finally.. front carbon bumper has been trimmed to fit the intercooler...
... and a hidden tow hook bolt.
Discussion Starter #117
There is something about packages from England....
A P2000 WRC replica...
A bit of a rough shape.. Not what I was expecting....
Discussion Starter #118
Apparently there is something wrong with the wing....
With the gap so big on the bottom its 2 wings in 1 !!!!
Discussion Starter #119
And on another note.. more progress !!!
Early morning began with Sti washer tank being welded in.
Since I dont know what happened to my dash bar... next on the menu was lightweight Vipec and Pdm mounts.
Here is a Vipec plate is going through its required diet procedure.
Thats gotta be at least 10 grams of AL!!!
Vipec's and Motec's new home.
Next up the firewall holes got welded up...
Not digging the look of this....
This needs to get covered somehow.
CF foot rests got installed today.
Here is the backing bracket.
This guy works so hard !!!
All I do is just take pictures.
All drilled up.
And now with the other side.
