1 - 20 of 96 Posts
2004 WRX Part Out 86k miles
Located in Fairmont WV or shipping isn't a problem just message me for a quote. If you want pictures of a certain part or interested in something not listed just ask.
Engine & Drivetrain
EJ20x Dual AVCS Heads (Bent Intake & Exhaust Valves w/o cams) $300
STi AVCS Intake Camshafts (Not from above heads & in good shape) $150
AVCS Cam Gears: IN RH #13320AA000, IN RH #13320AA001, IN LF #13322AA000, IN LF #13322AA001 $100
Coolant Hard Lines $30
Timing Covers $15 each
JDM Subaru Water Pump & Thermostat $50
OEM Harmonic Balancer / Crank Pulley $40
FXT Intake Manifold $100
Side Feed Fuel Rails $50
STi Fuel Pressure Regulator $35
Axles $100 each
Transmission Crossmember $100
Rear Differential "T" Crossmember $100
Rear Crossmember $150
Power Steering Lines $50
Power Steering Reservoir $25
Power Steering Pump Bracket $15
AC Compressor $100
AC Compressor Bracket $15
AC Lines $25+
AC Tensioner $30
AC Condenser $50
Washer Fluid Tank $20
Passenger radiator fan $25
Clutch Master Cylinder $35
Clutch Slave Cylinder $30
Clutch Fork $20
Clutch Line OEM $15
Pitch Stop $10
Wiper Motor $40
Wiper Linkage $30
Rear O2 Sensor #22690AA520 $35
Battery Power & Ground Cables $10
Horns $10 set of High & Low
Suspension, Wheels, Tires & Brakes
Rota Gforce 17x8 +48 Wheels with 225/45 General Altimax Artic Tires $700
OEM Struts & Springs $250
Front Driver Knuckle $100
Sway bars $25 each
Rear Aftermarket Endlinks $25
Front Aftermarket Endlinks $25
Trailing Arms with Brackets $40
Front Calipers $75
Front Rotors $25
Rear Rotors $25
ABS Sensors $25
Brake Master Cylinder $25
Brake Booster $50
Silver Kartboy Front License Plate Delete $20
Rear Doors $150
Rear Bumper $150
Rear Bumper Beam $100
Trunk with Wing $150
Wiper Arms $30
Wiper Motor & Linkage $40
Wiper Cowl $25
Driver A to C pillar trim $40
Passenger Roof Trim $40
Other Trim & Weather Stripping $10+
Dash $100
Cluster Surround $20
Door Handles $10
Passenger Airbag $50
Map Light $25
Dome Light $20
Bugeye Door Cards $50 set
Other plastics $10+
More Pictures:
1 - 20 of 96 Posts
