Looking to buy a subaru impreza L and its had the rear brakes swapped to disc (which i love) and i was wondering how id go about replacing them? would the same size for rs brakes and rotors work?
You would have to find out what rear disc brakes are on the car, its impossible for someone on here to know that. There are a bunch of different brake setups that could be on your car, rs brakes would be the most common.
So if you guys check out my build thread or instgram (gc22rs) I’ve been doing a ton of chassis and suspension work plus did 5spd swap and drum to disk brake swap. Was just about to get the car aligned and heard a weird noise from my timing area. Long story short my woodruff key slot has enlarged...
Hi everyone!
First off i have a 00 impreza wagon that i just got ahold of needs some tlc.
First question is im looking for complete struts including springs so i can bolt them up myself without a spring press. Will 98-99 legacy complete struts fit my impreza? I have done some research and...
need help deciding on a Motor I just bought a 94 1.8l AWD and it has 200k on it what motor should I plan on swapping in. it will be my DD and I will offroad/rally it. I plan on doing a full rsti swap for everything but the drive train. turbo is awesome but is the maintenance worth it? I have...
Of course the original plastic fuel door broke years ago (latch post snapped off), and I got several more years of use from a junkyard replacement. Then one windy winter day, I popped the door just as a big gust of wind came up from the right (or, wrong) direction…sounded like a plastic drink...
