1 - 8 of 8 Posts
so i've got a 2.2L and was just wondering what the 2.2 is. is the 2.5rs really superior or does that .3 matter at all?
the ej22 is the best engine subaru ever made. much more reliable than a 251, but does not have the torque or horsepower of a 251.
2000 2.5Rs Charcoal Grey
But what is the difference between EJ251 and EJ25E?
:hijack:
'04 PSM WRX Premium
EJ251
The EJ251 is a 2.5 L (2457 cc) Horizontally Opposed SOHC Engine with a bore of 99.5 mm (3.92 in) and a stroke of 79.0 mm (3.11 in). Compression ratio is 10.0: 1. Firing order is 1 - 3 - 2 - 4. SAE power:
123 kW (165 hp) and 226 N·m (167 ft·lbf)
Usage:
* Impreza RS 99-05 (US)
* Impreza Outback 00-04 (US)
* Forester 99-04
* Outback 00-04 (US)
EJ25E
SOHC 16 valve
Usage:
* Impreza RS 99~01
* Forester 99~00
* Legacy 00~01
'04 PSM WRX Premium
My Budget Build:
http://www.rs25.com/forums/showthread.php?t=80104
Things different on the 2.2 L than the 2.5 RS...
The L's supension is a little softer and ride height it shigher. The RS has alloy wheels and different size tires. And that .3 displacement makes a bit of difference (145HP compared to 165).
Either way, the 2.2 is a great car. It's the bulletproof engine, strongest made by subaru.
GF OBS-T, GM RS EJ20, SF EJ20
+1
2.2l = Dependable
2.5l = Blown Headgaskets
I have the same motor you have in my OBS-t & was able to run a slow 16.32 1/4 mile 3 times in a row when it was N/A with about $150 in mods + a fresh tune-up..
I was shifting @ redline, but I bet I could have run 15's if I shifted @ 5500RPMs.
Mods were
E-bay intake modded to pull cold air from fender
L/W crank pulley
Ground kit
Redline fluids in engine, tranny, & diff
I also had a WRX exhaust + high flow 2 1/4" cat - which did nothing for performance - just made noise....
My wagon came with 195/60 15's whereas most OBSs come with 205/60-15s which are taller & will yield a slower accelerating final drive.
Yeah I saw that on wiki but there is one saying US only, now I'm in Canada does it mean I have the other one. And what is the difference.
1 - 8 of 8 Posts
