Std. valves, three angle cut, surfaced, pressure checked, this set of heads does not come with cams, however, If you want the modified cams I will give you 25% off the cost of cam grinds and will need to do your cores.
Jon @ Delta Cam
Yes we have over 8500 pieces of tooling profiles.Can you do other cams as well, such as SR20DET cams?
OEM valves, standard valve dia. Just a nice fresh rebuild.how much are you expecting from these? and what kind of valves are they, are they oversized?
around $450.00I would love to buy these...I just do not have the money yet. How much is a job like that worth, for future reference..?
euro_pirate
$450 bone stock, to $1850 race We build the heads to match the customers budget. Some have more $ than others but all are good customers and we want to offer the most for the money !how much for a set of heads for a 2.5rs??
Are the prices the same for SOHC and DOHC?$450 bone stock, to $1850 race We build the heads to match the customers budget. Some have more $ than others but all are good customers and we want to offer the most for the money !
the DOHC heads cost more because the cams 4 vs. 2 and the amount of time it requires to set the valve lash in the DOHC. where the SOHC lash is simply set with a screw adjustment. The various stages are based on Valves requested,cams requested, and the biggest is port work cost and time.Are the prices the same for SOHC and DOHC?
Can you please show the price vs headwork for each step point all the way to $1850
