1 - 11 of 11 Posts
What do you guys recommend for under $500? I thought about a cold air intake and then I looked at the stock snorkel that pipes in air from the fender well. I'm not sure you could improve on that. So I was thinking axle back or even cat back exhaust but what else?
1998 2.2 Coupe
02 F-150 Extended Cab
i think you could do a light turbo kit for under $500. 5 PSI of boost is good for like 7 lbs and wont require any engine management except for maybe a FMU.
or do a 2.5 block swap and use the 2.2 heads, makes for a big bump in CR
Discussion Starter #5
Can't seem to find a SS stromung for under $500. How do the borla's hold up and whats the best site for impreza aftermarket parts?
also looking for exhaust recomendations. Do oem sti / wrx exhausts bolt up right or give us much gain? (I can't stand the stock pea shooter muffler)
04 Outback H6 aka old man car
Get some form of engine management (e.g. PP6) you can generally find it used for around $300. You can then accomodate any other mods that come your way.
97 OBS, 83 911, 13 Pilot
knockoff borla's
k&n panel filter
short shifter
wrx 20mm rsb w/ oem hd brackets
cough *sti catback im selling*
new plugs and wires
needs more cowbell
95L, 07 2.5i, R6
.. I paid 500 for my 2.5 dohc and swapped it in.. bingo, 50 instant hp :corn:
Oops, my mistake. I paid 450 for the engine and about 40 for the headers.
1 - 11 of 11 Posts
