1 - 20 of 356 Posts
1998 Forester on Orange 57F
For all those people looking to do a USDM WRX or STI swap this is your thread! I'm putting a list of swapped wires together to make the conversion really easy for people looking to do this themselves. If I have forgotten anything or if you would like to add anything don't be shy. These are guides I made for myself so I can follow them just fine but I don't know if anyone else thinks like me. Anyway here you are This is a start and cars that I have done so these should be correct. I would eventually like to add wire colors but I haven't got around to it.
Before you get started on your own project you might want to check out this merge I did. It will give you a step by step process of what to do. (It still under construction)
Brydon teaches you to merge
Just click on the links below and you will get to the wiring guide you are look for. Or scroll down to view them all. Let me know what I can do to make this more useful. I have lots of pictures of wiring merges but they are a little overwhelming when you first see them.
Conversion From 2002-2005 WRX to 1998RS
Conversion From 2002-2005 WRX to 1999/2000/2001
Conversion From 2004 STI to 1999/2000/2001
Conversion From 2005 STI to 1999/2000/2001
Conversion From 2006 STI to 1999/2000/2001
Conversion From 2007 STI to 1999/2000/2001
USEFUL STUFF TO KNOW BEFORE STARTING:
Immobilizer:
Drive by wire pedal plug for a 2005 STI:
Drive by wire pedal plug for a 2007 STI and Immobilizer Wiring. The Immobilizer wiring is the same but the 2007 Pedal was changed:
In this picture you can clearly see where the Immobilizer and Antenna and Key are located on the STI column:
Note: For all Immobilizer cars the Key, Immobilizer Unit, and ECU need to match in order for the car to start.
Fuel pump controller:
Fuel pump, DBW, ECU power relays:
All of them are listed below But I'm trying to get it layed out a little better!
Conversion From 2002-2005 WRX to 2000 RS Pinout
Description - WRX pin location - RS pin location
*VSS B134/1 - B135/24
*Starter Switch B134/16 - B135/28
*A/C Switch B134/2 - B135/27
*Ignition Switch B134/5 - B135/7
*Neutral Position B134/8 - B135/26
*Test mode connector B134/14 - B135/14
*Back-up Power B137/10 - B136/9
*Control Power B137/2 - B136/1
*Control Power B137/3 - B136/2
*Sensor Power Supply B135/9 – B136/15
*Ground (Power Supply) B136/17 - B134/8
*Ground (Control System) (B134/7&15) – (B135/6&25)&(B136/21&22)
*Self Shutoff Control B134/6 - B135/19
*Line End Check 1 B134/10 – B135/20
*Line End Check 2 B134/20 – B135/12 This is the OBDII connector Pin 5 but needs to be moved to pin 8 to make reflashing possible (Doesn’t exist on the RS so you need to Repin the OBDII connector or try switching to a 2002+ OBDII connector.)
*A/C relay B137/27 - B134/17
*Fan1 Relay B137/17 - B134/3
*Fan2 Relay B137/28 - B134/12 *Changed from actually wiring diagram one says pin2*
*CEL light B137/15 - B134/11
*Tach B136/9 - B134/30
*fuel tank pressure sensor B135/15 - B136/12
*Fuel tank pressure solenoid B137/22 - B134/1
*Drain valve B137/11 - B134/10
*Fuel level sensor B135/25 - B136/27
*Fuel temp sensor B135/6 - B136/26
*Small light B134/17- B136/3 (Doesn’t exist on 99 RS only on 2000+)
*Blower fan switch B134/9 - B136/30 (Doesn’t exist on 99 RS only on 2000+)
*Rear defogger Switch B134/3 - B135/21 (Doesn’t exist on 99 RS only on 2000+)
*SSM/GST Communication line B134/21 - B135/3
*Not complete still need powers and grounds and randoms*
Addition Wiring on the 1999/2000?/2001? RS harness:
OBDII Connector Pin4 B135/11 (G/W) - Not Used for the WRX
OBDII Connector Pin5 B135/12 (Lg/R) - Not Used for the WRX But I use this wire for pin8 for reflashing. This needs to be changed at the OBDII connector.
Fuel Pump Relay Control B134/16 – T’ed to B135/19 (This makes the relay on when the key is on.)
W/G RS >>>Water temp>>> W/G WRX to dash gauge
G/W or G/B RS>>>>Oil pressure >>>G/W WRX to dash light.
Addition Wiring on the 2002 WRX harness:
Injectors/Ignition needs switched 12volt Power
2002 WRX Fuel Pump Controller
R122/1 (B) - To the ground leading to the fuel pump (B)
R122/2 (V/W) - Wired directly to the ECU
R122/3 (B/Y) - Wired to the 12Volt power leading to the fuel pump (B/R)
R122/4 (B/W) - Wired to negative side of fuel pump (B)
R122/5 (Lg/R) - Wired directly to the ECU
R122/6 (B/Or) - To positive side of fuel pump (B/R)
Conversion From 2004 STI to 1999/2000 RS Pinout
Description - STI pin location - RS pin location
VSS B135/27 - B135/24
Starter Switch B137/8 - B135/28
A/C Switch B137/16 - B134/17
Ignition Switch B137/15 - B135/7
Neutral Position B137/9 - B135/26
Test mode connector B137/14 - B135/14
Back-up Power B135/19 - B136/9
Control Power B135/5 - B136/1
Control Power B135/6 - B136/2
Sensor Power Supply B136/16 -
Evaporation Thermo Switch B135/7 - B135/27
A/C relay B135/33 - B134/17
Fan1 Relay B135/25 - B134/3
Fan2 Relay B135/24 - B134/12 *Changed from actually wiring diagram one says pin2*
CEL light B134/17 - B134/11
Tach B134/23 - B134/11
fuel tank pressure sensor B136/21 - B136/12
Fuel tank pressure solenoid B134/12 - B134/1
Drain valve B134/13 - B134/10
Fuel tank valve B134/24 - Not on the RS body will need to be flashed out.
Fuel level sensor B136/20 - B136/27
Fuel temp sensor B136/12 - B136/26
Small light B137/12 - B136/3 (Doesn’t exist on 99 RS only on 2000+)
Blower fan switch B137/13 - B136/30 (Doesn’t exist on 99 RS only on 2000+)
Rear defogger Switch B137/11 - B135/21 (Doesn’t exist on 99 RS only on 2000+)
SSM/GST Communication line B137/20 - B135/3
OBDII Connector Pin4 B135/11 (G/W) - Not Used for the STI
OBDII Connector Pin5 B135/12 (Lg/R) - Not Used for the STI
OBDII Connector Pin8 B135/21 (W/R) - Not Used for the STI
Line End Check 1 B135/20 (R/W) - Not Used for the STI
Fuel Pump Relay Control B134/16 – B137/15
^^^****The Opposite side of the fuel pump relay now needs to be ground instead of power. This can be tapped off of the main relay****
Self Shutoff Control B135/19 – B137/15
W/G RS >>>Water temp>>> W/G STI to dash gauge
G/W or G/B RS>>>>Oil pressure >>>G/W STI to dash light.
Addition Wiring on the 2004 STI harness:
Throttle Control relay needs switched 12volt power
2004 STI Fuel Pump Controller
2004 STI Cruise Control:
B134/16 - Set light on dash - B161/6 (B)
B134/15 - Cruise light on dash - B161/4 (V)
B134/1 - Clutch switch - B94/9(L/Or)
B136/11 - Set/coast - B94/6 (Lg/B)
B136/9 - Brake switch1 12v switch - B94/8 (R/Y)
B136/8 - Brake switch2 12v switch - B94/19 (W/B)
B136/10 - Resume/accel - B94/7 (R/W)
B136/7 - Cruise button on - B94/4 (Br/W)
**RS Connectors at stock cruise module**
B94/5 (Y/G) spliced to B94/3 (G/B)
B161/2 need to be T’ed to B161/1
B107/1 needs to be T’ed to B94/8
Conversion From 2005 STI to 1999/2000 RS Pinout
VSS B135/26 - B135/24
A/C Switch B137/17 - B134/17
Ignition Switch B137/14 - B135/7
Test mode connector B137/15 - B135/14
Sensor Power Supply B136/16 – B136/15
Evaporation Thermo Switch B137/16 - B135/27
Immobilizer B137/19 - Immobilizer/Pin10
Immobilizer B137/27 - Immobilizer/Pin23
Fuel Pump Relay Control B134/16 – B137/14
Self Shutoff Control B135/19 – B137/14
Addition Wiring on the 2005 STI harness:
2005 STI Fuel Pump Controller
2005 STI Cruise Control:
Immobilizer Pinouts:
Pin 1: Antenna
Pin 2: Fused 12v power (Power into Main Relay)
Pin 3: Fused 12v power (Power into Main Relay)
Pin 5: Security Light on dash ???
Pin 8: Door light switch (Yellow wire from doors, color is the same on STI and 99RS)
Pin 9: Keyless entry wire but T'ed to impact sensor. This does not exist on the 99 RS. But I think you will be ok.
Pin 10: ECU wire (B137/19)
Pin 14: Antenna
Pin 15: Ground (B137/1)
Pin 23: ECU wire (B137/27)
Pin 24: Ignition fused 12v Power (B135/19)
Pin 25: Ground (B134/5)
Pin 26: Ignition Starter & Steering Lock assembly T’ed to (B137/14)
Conversion From 2006 STI to 1999/2000 RS Pinout
Evaporation Thermo Switch B137/17 - B135/27
Addition Wiring on the 2006 STI harness:
2006 STI Fuel Pump Controller
2006 STI Cruise Control:
Pin 1: Antenna
Pin 14: Antenna
Conversion From 2007 STI to 1999/2000 RS Pinout
VSS B136/13 - B135/24
Backup power supply B135/5 – B136/9
Starter Switch B136/32 - B135/28
Ignition Switch B135/19 - B135/7
Neutral Position B136/31 - B135/26
Test mode connector B135/27 - B135/14
Line end check - nothing
Control Power B134/7 - B136/1
Control Power B135/2 - B136/2
Evaporation Thermo Switch B136/24 – B135/27
A/C relay B136/9 - B134/17
Fan1 Relay B136/18 - B134/3
Fan2 Relay B136/29 - B134/12 *Changed from actually wiring diagram one says pin2*
CEL light B136/11 - B134/11
Tach B136/22 - B134/30
fuel tank pressure sensor B135/32 - B136/12
Fuel tank pressure solenoid B136/28 - B134/1
Drain valve B136/17 - B134/10
Fuel level sensor B135/10 - B136/27
Fuel temp sensor B135/17 - B136/26
Small light B135/15 - B136/3 (Doesn’t exist on 99 RS only on 2000+)
Blower fan switch B135/16 - B136/30 (Doesn’t exist on 99 RS only on 2000+)
Rear defogger Switch B135/14 - B135/21 (Doesn’t exist on 99 RS only on 2000+)
SSM/GST Communication line B136/16 - B135/3
5Volt Power supply B135/22 - B136/15
Immobilizer B136/26 - Immobilizer/Pin10
Immobilizer B136/34 - Immobilizer/Pin23
Self Shutoff Control B136/23 - B135/19
AT/MT identification signal – T’ed to ground
CAN communication + B136/27 –
CAN communication – B136/35 –
Addition Wiring on the 1999/2000/2001 RS harness:
Fuel Pump Relay Control B134/16 – B135/19
^^^****The Opposite side of the fuel pump relay now needs to be ground instead of power. The Main Relay needs to be power instead of ground. This can be done by swapping the Main Power Relay and Fuel Pump Relays power and ground. These are the wires opposite the side that go back to the ecu****
2007 STI Fuel Pump Controller
2007 STI Cruise Control:
B135/3 - Set light on dash - B161/6 (B)
B135/6 - Cruise light on dash - B161/4 (V)
B135/12 - Cruise button on - B94/4 (Br/W)
B135/13 - Resume/accel - B94/7 (R/W)
B135/20 - Brake switch 12v switch - B94/8 (R/Y)
B135/24 - Set/coast - B94/6 (Lg/B)
B135/28 - Brake switch 12v switch - B94/19 (W/B)
B136/25 - Clutch switch - B94/9(L/Or)
Pin 1: Antenna
Pin 8: Door light switch (Yellow wire from doors, color is the same on 07STI and 99RS)
Pin 10: ECU wire (B136/26)
Pin 14: Antenna
Pin 15: Ground (B134/5)
Pin 23: ECU wire (B136/34)
Pin 24: Ignition fused 12v Power (Power into Main Relay)
Pin 26: Ignition Starter & Steering Lock assembly (B135/19)
UPDATE:::
Conversion From 2002-2005 WRX to 1998 RS Pinout
VSS B134/1 - B84/83
Starter Switch B134/16 - B84/86
A/C Switch B134/2 - B84/60
Ignition Switch B134/5 - B84/85
Neutral Position B134/8 - B84/82
Test mode connector B134/14 - B84/84
Back-up Power B137/10 - B84/39
Control Power B137/2 - B84/1
Control Power B137/3 - B84/2
Sensor Power Supply B135/9 – B84/21
Ground (Power Supply) B136/17 - B84/19&46
Ground (Control System) (B134/7&15) – (B84/17&18
Self Shutoff Control B134/6 - B84/63
Line End Check 1 B134/10 – (Doesn’t exist on the 1998 RS so you need to Repin the OBDII connector or try switching to a 2002+ OBDII connector.) B84/91 Leads to the OBDII connector but is in the B40/5 needs to be in the B40/6 position
Line End Check B134/20 – (Doesn’t exist on the 1998 RS so you need to Repin the OBDII connector or try switching to a 2002+ OBDII connector.) B84/92 Leads to the OBDII connector but is in the B40/4 needs to be in the B40/8 position
A/C relay B137/27 - B84/31
Fan1 Relay B137/17 - B84/74
Fan2 Relay B137/28 - B84/73
CEL light B137/15 - B84/58
Tach B136/9 - B84/64
fuel tank pressure sensor B135/15 - B84/4
Fuel tank pressure solenoid B137/22 B84/10
Drain valve B137/11 - B84/35
Fuel level sensor B135/25 - B84/27
Fuel temp sensor B135/6 - B84/25
Small light B134/17- (Doesn’t exist on 98 RS only on 2000+)
Blower fan switch B134/9 - (Doesn’t exist on 98 RS only on 2000+)
Rear defogger Switch B134/3 - (Doesn’t exist on 98 RS only on 2000+)
SSM/GST Communication line B134/21 – B84/93? <The diagram I have is distorted
OBDII Connector Pin4 B135/11 (G/W) - Not Used for the WRX but see note above for swapping.
OBDII Connector Pin5 B135/12 (Lg/R) - Not Used for the WRX but see note above for swapping.
Fuel Pump Relay Control B84/32 – T’ed to ground (This makes the relay on when the key is on.)
B137/23
1999 ver7 coupe
Wow +1
My swap is already done but you have just saved countless people many hours of work and hundreds/thousands of dollars.
If you could add an older JDM (ver5-6?) and newer JDM (ver7+) guide then I think this would be about complete, although it's already probably the most useful technical post on this entire forum.
03 wrx srp
Along with this diagram also dont be afraid to start cutting out random wires you dont need. I have watched Brydon do this and it was ummmm how should I say suprising how ungental he was...lol:eek:mg:
1999 Subaru Impreza 2.5 rs-t
lol. yeah, that's probly going to be hard to do for people that need this thread. theres no turning back at that point. but I guess Brydon is making it so simple anyway.
I've said it once and i'll say it again, Brydon, you are the man.
project blackbird.
'01 RS, '81 Fiat Spider
I bookmarked this the second I saw it. Brydon, you are incredible. Thanks!
'06 LGT
Awsome!
Although I think this might put ECS out of business.
Discussion Starter · #11 ·
Awsome!
I highly doubt it! In my experience the people that don't wont to try will always pay to have this done. For the more adventuresome that would tackle a project like this themselves, it will just make the project a little faster and easier. Besides I even tell people to buy the pedal adapters from ECS. They have proven to be a quality product.
When I do this on my own car in the next month I will take a lot of pictures of changing the crossmember and power steering. And also some of the more hidden bolts on the dash and how all that comes apart. Maybe even throw in some pictures mounting the fuel pump controller and how I wire the controller itself.
2017 WRB BRZ w/PP
I'll be very interested to see these!!! It's the one part of the swap I'm somewhat in the dark about.
2001 Subaru Impreza 2.5rs
Thanks for your help so far through PMs man, this thread has already got so much useful information in it. I'll try and take some pics while I'm working on my 05 swap in a week.
I'm sure this thread will get stickied too. (It better at least!)
Discussion Starter · #14 ·
2006 WRX
Brydon - last question before I tape up the harnesses. The O2 sensor heating circuit in the RS ties into the RS main relay. the STI has its own circuit independent of anything on the RS. Is it fine to remove the wire from the RS main relay since the rest of the wires aren't connected to anything?
FYI, I can add pictures and elaborate on the "randoms" if you'd like. I have a picture for 99% of the wires I soldered.
00 2.5RS Coupe, Ducati Monster
Thank you so much for this thread. I am in the middle of this wiring nightmare.
Edit: This thread needs to be a sticky!
Discussion Starter · #17 ·
You should be using the STI front and rear o2 sensors. The heater wire is Yellow/Red on the STI harness and leads directly back to the main relay. I only use the RS relays so I had to change this over. I remember you saying you are using the STI relays.?. If so they should already be wired to that relay.
On the RS side you should be able to ignore the heater wire or use it for something else you need power for. It is just a relayed 12v source.
2006 WRX
Perfect. I'll fire the rest of the pics up for the '07 merge in my thread tomorrow, feel free to use them.
2006 WRX
I should also clarify one thing here.. If you keep both the RS and STI relays, there will be less wires to merge. All you need to do is delete the fuel pump relay control wire (Lg/B IIRC) and T the two main relay control wires together (Lg) and you get rid of a few wires for the immobilizer and you also have the proper wiring for the fuel pump controller.
Example:
R122/1 (B) - To the ground leading to the fuel pump (B) --> Wire is present on the STI relay
R122/3 (B/Y) - Wired to the 12Volt power leading to the fuel pump (B/R) --> Present on STI Relay
That way, you can make up a harness containing the two ECU wires and the B/Y and B wires from the STI Fuel Pump relay and run it all the way back.
Brydon, feel free to correct me but this is what I have found by searching through the wiring diagrams and staring at my harness for countless hours
Currently scamming 3 members
SRP 2000 Subaru Impreza 2.5 RS
awesome but you put this up a day too late, ahh i just scheduled my swap with 1320..ohh well... this is great fr the next time i do this...hahaha
1 - 20 of 356 Posts
