Up for sale is my 1998 Subaru Impreza RS coupe project. Located in Orlando, Florida.
Shell is a blue 1998 RS coupe with STi BBS wheels, WRX brakes, new carpet, wrx seats, interior and exterior in good
condition. Clean carfax. I have a signed Colorado title from the previous owner, and the vin verification has already
been done, though I will probably be transferring the title to my name this week, either way, clear title.
Parts included with this project:
Engine and fuel:
New 2.5l STi block
New Forced Performance 68HTA w/8cm turbine housing
2.0 liter head castings CNC machined to have the same combustion chamber as STi
Stock 2.0 liter cams, valves, valve springs and shims (Heads not assembled)
New STi gasket set
TGV deletes (still need the holes welded)
Stock Intake manifold and fuel rails
Stock exhaust manifold and cross over pipe
Engine wiring harness
New 2.5l oil pan
New 11mm STi oil pump
New Gates timing set with kevlar belt, all new pullies and tensioner, and new water pump.
New ARP Head studs
New Catless up pipe
New Catless bellmouth downpipe
3 inch exhuast
New Grimmspeed electronic boost control solenoid
New 160 degree thermostat
New silicone turbo inlet
New silicone after maf tube
New big tmic
New silicone intercooler couplings w/ tbolt clamps
New Turbosmart vent to atmosphere BOV
New Walbro 255lph fuel pump
Drive train:
New STi flywheel
New ACT heavy duty clutch (full face, sprung hub)
Exterior:
Jdm aluminum RS hood
New RS bumper
Also included:
Harbor freight engine stand
Harbor freight parts washer
Stock RS 5spd tranny
all bolts needed for engine and car assembly
stock WRX injectors
wrx power steering pump
2 sets of RS headlights
RS grill
Numerous other wrx and RS parts
The set up I was going for was intended to produce near 400 AWHP. A friend of mine did a similar build and made
370hp/412ft lbs
All in all I estimate that I have spent around $10k I am listing this for $9,000 OBO. Reason I am selling is
because I do not have the funds to finish. Please call or text (407) 402-8000 for any inquiries, or offers. Thanks.
Engine and fuel:
New 2.5l STi block
New STi gasket set
New 2.5l oil pan
New ARP Head studs
New Catless up pipe
3 inch exhuast
New big tmic
Drive train:
New STi flywheel
Exterior:
New RS bumper
Also included:
stock WRX injectors
RS grill
370hp/412ft lbs
