Hello all,
I remember reading on either here or Nasioc someone measuring a Subaru roll pin and it was a tad under 1/4" in diameter. Will a Spring pin with the above specs fit in a Subaru axle? Napaonline has Roll pins with the same specs but they are $5 each as opposed to the spring pin which is like $0.38 each. Is this a good idea? (using the spring pin as opposed to the roll pin). Thanks.
On a side note, NO ONE sells spring or roll pins in store. NO ONE!
