1 - 4 of 4 Posts
98 impreza rs black 06 wrx swap
I'm trying to install the feed line but there isn't much room between the damper and the fuel filter. Is it ok to remove the fuel dampers? If not could I remove the oem hoses and just use regular fuel hose.
98 Coupe Race Car
Yes and no, I do not believe there are many adverse effects besides turbulence in the fuel flow to the injectors possibly effecting spray patterns. Yes you're fine to run without them its not going to hurt anything. No, you should make them work because factory engineering > some guy with bread in his name on the internet.
I just ripped the fuel hose trying to remove to change the filter. The hose is too hard to remove and install on the filter. What are my options?
1 - 4 of 4 Posts
