1 - 3 of 3 Posts
2005 Subaru Impreza 2.5rs
Hi yall
I have an 05 2.5rs and an 04 WRX donor car
The donor is rotted out and i got it for 1800 with a very healthy EJ257 and wrx tranny in it.
I should have everything i need but would like a full check list of all that has to be done.
Like, will i have to change the cv axles?, spindles? Will the 2.5rs driveshaft go into the WRX diff and trans? Will i have to add a fuel line?
Im going to be taking the fuel pump from the WRX anyways.
And no, i will not just "buy a WRX" once this is all said and done. I will have a swapped 2.5rs with a good non rotted body for $2700.
Assuming i have everything i need on hand.
Thank you.
www.jackstalk.com
I would personally swap over all of the WRX stuff that you can, including the hubs and everything. 04 to 05 have different axles.
1 - 3 of 3 Posts
