1 - 3 of 3 Posts
97 RHD Twin turbo legacy wagon
im swapping my 02 wrx full drive train to my 97 impreza is has JDM V2 wrx rear hubs and when i tighten up the axle nut the axle pulls in to far and binds against the hub, anyone have this problem or a solution to it... lemme know... i know the jdm V4 sti axles fit in because i had that will my 4.44 setup in the 97 before, then swapped into the stock 02 hubs fine!
yep. you heard me.
‘18 E63s AMG wagon & 10 Subarus
do the axles have ABS sprockets on them? because some hubs have abs in the hub, not on the axle, so the ABS axles with sprockets on the axles dont work (i could be wrong)
no abs sprokets on them....abs on rear is part of the hub i belive too
1 - 3 of 3 Posts
