I have not updated this in ONE YEAR! See the videos for recent activity!
Intro: I Bought a Rare Subaru Impreza 2.5RS Rally King! STI Powered GC8 RSTI - YouTube
Everything Wrong With My Subaru Impreza GC8. RSTI Project Needs Work: Part 2: Everything Wrong With My GC8. The RSTI Project Needs Work - YouTube
Subaru Impreza GC8 Build Gets Bigger Injectors: Part 3 Subaru Impreza GC8 Build Gets Bigger Injectors: Part 3 - YouTube
Fuel Pump Install on the GC8 Build: Subaru Impreza 2.5RS Part 4 Fuel Pump Install on the GC8 Build: Subaru Impreza 2.5RS Part 4 - YouTube
Cobb APV3 Install: Part 5 Project Impreza 2.5RS: COBB Accessport V3: RSTI GC8 Build Part 5
Upgrading the Manual Boost Controller to Grimmspeed Electronic Boost Controller: Part 6 Electronic Boost Controller Install: Subaru Impreza 2.5RS GC8 RSTI Part 6
Please Subscribe!
Road Patina
- YouTube
The story of a second hand build in need of some TLC.
I have built a few Hondas/dirt bikes/quads over the course of the past 15 years but never a Subaru. This time around I wanted a car with the majority of the heavy work completed, for I do not have the time or room for a ground up build.
I remember drooling over the 2.5RS when they hit the showrooms when I was in high school. After searching the entire USA for a clean RSTI for over 8 months, I pulled the trigger on one 2000 miles away. The car was in GA and I was in CA but did not let the distance stop me. Grabbed a buddy and after a total of 20 hours at a series of airports, the deal had been made and the car was set to be shipped to its new home!
Table of contents:
1) WTB-Parts I need. Post 2
2) Rust repair. Post 3
3) Sound deadening removal. Post 5
4) Oil leak. Post 9
5) DIY floor board drain plugs. Post 10
MODS!
Engine/Transmission
• Cobb AP v2
• EJ257 block
• CP Forged 2618 pistons
• ACL Race bearings
• ARP Head Studs
• Cosworth 12mm Oil pump
• 03 WRX Heads with STI cams, flow tested
• REV SS +1mm Intake & Exhaust valves, nitrided, hardened tips
• Bosh 1000cc injectors
• Deadbolt 18G port, polish, clipped and heat treated
• Custom stainless steel braided turbo oil feed line
• PPG 5MT with chipped 2nd gear
• ACT lightweight Flywheel with interchangeable contact surface
• ACT 6 Puck sprunk clutch disk and Pressure Plate rated at 425ft lbs
• Turbo XS (I think) FMIC core with APS piping
• Cobb short throw double adjust shifter
• Torque solutions shifter bushing kit
• HKS Carbon fiber titanium Exhaust
• Maddad equal length Header
• Tial 44 external waste gate
• Nvidia catted downpipe
• Perrin Inlet pipe
• Mizu Aluminum Radiator
• Forge Recirc BOV
• TGV Deletes
• Injen short ram intake
• IXIZ Pitch Stop
• Group N Motor and Tranny mounts
• Stainless Steel Braided Power Steering line
• Upper and lower silicone radiator hoses
• Killer B pickup and windage tray
Suspension/Brakes
• Tein Flex CO's with EDFC (rebuilt ~12k ago)
• Wilwood 6 piston front big brake kit 13.3” X drilled Slotted rotors
• Wilwood 4 piston rear big brake kit 13.1” X drilled Slotted rotors
• Wilwood Stainless steel brake lines
• Whiteline front sway bar and endlinks
• Whiteline rear sway bar and endlinks
• Whiteline front race anti-dive caster kit
• Whiteline rear front trailing arm bushing kit
• Whiteline front roll-center/bump steer adj. kit
• Whiteline front lower inner control arm bushing
• Whiteline rear subframe lock kit
• Whiteline rear control arm bushing kit
• Whiteline plus diff cradle mount
• Whiteline rear diff support lock
• WhiteLine steering rack bushings
• STi aluminum control arms
• STI steering rack
• STi carbon fiber front strut bar
• JDM rear strut bar of some sort
• 03 WRX dash swap
• Katzskin 2 tone leather seats from 03 WRX
• JPM Coachworks door cards front and rear to match seats
• STi EDM black face gauge cluster MPH
• New OEM 2.5RS carpet
• New OEM 2.5RS floor mats
• New OEM rear trunk mat
• Autometer oil pressure and boost gauge in cluster pod
• Kenwood head unit
• JL 6.5 components
• JL 12W6 sub
• Massive audio amps
• JDM red hazard switch
Body/Exterior
• OEM 2.5RS re-painted with 2 coats of clear (AMAZING how much red metallic with a fresh paint job)
• Carbon fiber fender flares painted to match (fenders cut, welded, sealed with welded screw inserts where applicable
other hardware used for plastic areas)
• Carbon fiber hood scoop painted to match
• RS hood scoop also
• Depo headlights
• Hella supertone horns
• Prodrive CF front lip spoiler (Cracked)
• Oem Side Skirts
• XXR 522 18"
• Michelin PSS 265/35r18
• ARP extended wheel stud kit
• JDM corner lights
• In-fender coolant tank
• 22B rep hood vents
• Garbage Kartboy poly exhaust hangers
• Custom side mount front plate
How the car appeared in the two year old classified add.
Let the journey begin!
Please Subscribe!
Road Patina
- YouTube
Table of contents:
4) Oil leak. Post 9
MODS!
Engine/Transmission
• Cobb AP v2
• EJ257 block
• ACL Race bearings
• ARP Head Studs
• Perrin Inlet pipe
• Forge Recirc BOV
• TGV Deletes
• IXIZ Pitch Stop
Suspension/Brakes
• STI steering rack
• 03 WRX dash swap
• Kenwood head unit
• JL 6.5 components
• JL 12W6 sub
Body/Exterior
• Depo headlights
• Oem Side Skirts
• XXR 522 18"
• JDM corner lights
