1 - 8 of 8 Posts
2001 impreza rs black
Im in the market for new struts, as of right now I can't afford a good coilover system. Im looking to spend around $600, more if needed. What are some good brands and should I reuse my existing spring or buy new ones and if so what kind? Any knowledge will help thanks
1995 JDM WRX
1999 RSTi coupe
KYB seems to be the one to go with. AGX if you want adjustability or Excel-G (formerly called GR-2)for stock like performance. Tokico has no love for the GC/GM/GF guys.
Discussion Starter #5
would any brand of springs fit with the kyb's? im not looking to lower my car because of how bad the roads are in michigan, im just looking for some sturdy ones that can take some wear and tear
Black 98 RS
Since your worried about the height of your car you should just stick with the stock springs because there are almost no aftermarket springs that offer stock height.
00'RS/02' WRX stgEleventy
If you buy struts, replace the top hats(mounts) at the same time.. they have the same mileage on them and are just as worn out.. your car will thank you and you wont be going back in in a month to replace one that will inevitably fail
1 - 8 of 8 Posts
