1 - 9 of 9 Posts
91 LSi w/EJ22T
I have a chance to get a set for a good price, are these a good upgrade, and will they change the exhaust sound a little?
overdeveloped beater
Stock headers? They'll fit.....but your cat may not. It won't be an upgrade anyway. Check it first.
Banned
1997, Subaru, Impreza L, 2.2L,
Is your 95L single port or dual port? If its dual port it will fit. I don't see why the catalytic converter part wouldn't, but I could be wrong.
I had problems going from an EJ18 cat section to an RS midpipe. I never did put a Borla on that motor so I meant it more as a YMMV type thing.
The header itself will fit but they are the same size as the EJ18......
so does it mean that i can go to ebay and buy a 2.5rs header and dump it on a 1997 Subaru IMpreza L? or TS?
Thanks
2002 WRX Wagon
Yes, that should work out fine, although someone else should verify that for you before you go ahead...
impreza base!
somewhere around 96 or 97 they switched over to single port exhaust manifolds... u should check which ones u have before buying
97 EJ22 is single port. You're SOL.....unless you know how to weld.
Thanks
1 - 9 of 9 Posts
