2005 2.5RS Front Rotor Upgrade, RS to WRX - Subaru Impreza GC8 & RS Forum & Community: RS25.com
Old 05-20-2008, 05:51 AM   #1
SiFuSpEc
2.0L
Car: 2005 2.5RS AW #78 SM B!
Fav Mod: Tires
Default 2005 2.5RS Front Rotor Upgrade, RS to WRX
Figured this would be useful information, for those like myself who can't afford Brembo or equivalent upgrade brakes..
My car hit 100,000 miles the other day, in its 100,000 miles run, it has had one set of brake pad change (Hawk HPS), and about 60 autocrosses.
So my rotors were toast after 3 or 4 runs at an larger course autocross the brakes would fade and the pedal would become all mushy and useless, I had to solve this problem, since my rotors were pretty mangled, I had read on both NASIOC and 25RS as well as ScoobyMods about RS owners upgrading their rotor size to WRX rotor size. Year depending, my 2005 had the 276mmx24mm rotors. WRX bears the 294m24mm rotors. It's a good 18mm bigger in diameter.
Instead of just buying new RS rotors and being done with it I decided to get WRX brake caliper brackets and run the WRX rotor sizes.. It's a cost effective way to get the most out of the OEM braking system without converting to either the OEM Subaru 4-Pot/Big Rotor upgrade or Brembo/Equivalent.
I've taken some comparison shots to show what difference there is..
Caliper Brackets:
Rotor Difference:
Finished:
This improvement is probably more noticeable on the older GC RS's, which pending on year may have the 260mmx24mm rotors. This would be a huge improvement for those cars..
I haven't finished doing the rest of the brakes yet so i'll update with feedback.
I'm on HAWK HPS right now, but primarily will be using these with the better compound HAWK HP+ later this month, maybe next.
There was raised concern when I posted this over on NASIOC by an individual about the 8% torque increase in the front due to this upgrade..
Personally 8% is not something i'd worry too much about if I knew there was better heat management, stability (instead of possibly having too much rear bias and looping it braking hard into a corner) and would only be more critical if I had done a major upgrade, 4pot Rotora/Stoptech/Brembo.
Hope this helps those questioning, if need be I can put up part #'s.
05' 2.5RS Pro Aspen White
#78 SM AutoX Attack B!
SiFuSpEc is offline   Reply With Quote
Old 05-20-2008, 06:52 AM   #2
Boxer4Dad
2.7L
Car: 2005 Saabaru 2.5i
Fav Mod: Better tires
You're right about the increased brake bias in the front, but I (also) think you'll be fine. If you ran more brake in the rear, it could well become a handful as you say. More in front will be a help. I use better pads in front on my car to accomplish this. I say enjoy it.
"Is it windy?" "Nah, Thursday" "Me too. Let's grab a beer."
Boxer4Dad is offline   Reply With Quote
Old 05-20-2008, 10:57 AM   #3
LandCruzer94
Car: White 05 RS Sport Pkg
Fav Mod: Whiteline ALK
Trader Rating: (5)
Looks good! I'm actually getting this setup in the mail today as well as my H6 rear swap, should be fun! I'll post a thread on this subject as well
Check out my rally photography and buy prints at the new www.kylefunsten.com!
LandCruzer94 is offline   Reply With Quote
Old 06-28-2013, 11:44 AM   #4
trx450r1989
Car: 2000 rs2.5/96 brighton ej20
Does it matter what year wrx the brackets or rotor come from. Will 03 work?
Aerodynamics are for people who canít build engines.
trx450r1989 is offline   Reply With Quote
Old 06-28-2013, 12:24 PM   #5
pho_shizzle
Car: MY00 GC6 BRP
Fav Mod: Pho Driver Mod
Trader Rating: (15)
03-05, not 02.
pho_shizzle is offline   Reply With Quote
Old 12-13-2014, 02:53 AM   #6
andrewjt19
Fav Mod: Royal Purple
Does anyone know if this general rule is applicable to the rear brakes as well? I'd love to do a full brake upgrade all around....
'05 Impreza RS --> '05 Impreza rSTi (soon )
andrewjt19 is offline   Reply With Quote
Old 12-13-2014, 04:24 AM   #7
CO671
Fav Mod: Trial Hood&Liberal Grill
Trader Rating: (3)
Legacy H6 rear caliper brackets + rotors
DIY: "H6" Brake upgrade for 02-05 WRX/Impreza *Including 04-05 specific info* - NASIOC
excluding brake pads, this is how much the rotor + caliper bracket setup would cost you via RockAuto
[assuming 15201 is a zip code near your location]
CO671 is offline   Reply With Quote
Old 12-13-2014, 10:15 AM   #8
EVL RS-T
Like CO671 posted... the brake upgrade for the rear is either the H6 rotors (290mm solid) or the LGT rotors (294mm vented - NorthUrsalia.com: Legacy GT Turbo Vented Rear Brake Swap). The WRX rear rotors were the same as our RS rotors.
KNS brakes has the kits as well.
EVL RS-T is offline   Reply With Quote
Old 12-13-2014, 12:07 PM   #9
andrewjt19
Thanks guys for the answers. Just to clarify, I have an 05 RS so the rear 05 WRX rotors and brakes are identical to mine?
Old 12-13-2014, 12:19 PM   #10
EVL RS-T
To be honest, I don't know the answer to this... anyone else?
