Wheel bearing replacement - Subaru Impreza GC8 & RS Forum & Community: RS25.com
Old 04-07-2019, 11:55 AM   #1
monoposto
Default Wheel bearing replacement
I need to replace all four corners. But before I go about doing this the difficult way by pressing in new bearings.
I seem to recall someone saying to just purchase the whole assembly? Can I get this anywhere?
Also is there a newer upright combination that will work the the gc but with bolt in bearings instead of pressed?
monoposto is offline   Reply With Quote
Old 04-15-2019, 08:52 AM   #2
Rigid80smtb
1.8L
Car: 96 Impreza, 03 WRX
Fav Mod: Oil swap
I'm in the same boat. I've looked all over the place and can't find any new front bearing/hub assemblies. Hate having to deal with these stupid press in bearings.
Don't mean to hijack either but does anyone know if a 93 fwd front hub/bearing will fit on a 96 awd? I just got a new wheel bearing put in but now there's a squeak/vibration because the hub is worn out and I refuse to keep putting a bunch of money into this dumb shit.
Rigid80smtb is offline   Reply With Quote
Old 04-17-2019, 05:14 AM   #3
Samurai Jack
1.8L
Car: 2002 WRX
Fav Mod: Enemy of Aku
You can purchase all new parts, but it gets very expensive quickly.
Pressing in new bearings is not that difficult, as long as you have the right tools and you have the skill level.
Another option is to call a reputable JDM Importer. There are many interchangeable parts between the years and it may be possible to purchase a used complete assembly with lower miles. I recommend JDM Racing Motors in Canada. Really good people to work with.
Also, this may help you out: Subaru 2.5RS wheel bearing assembly - Google Search
Another possible solution:
It may be possible to swap a 2005 STi front hub and wheel bearing assembly, which comes with bolt-in bearings, BUT there is a catch -
1. Very expensive option
2. These hubs come with 5x114.3 wheel stud spacing, so you would have to re-drill the hubs ( yes, can be done )
3. You would have to switch to STi front stuts
As for the rear wheel bearings, they are press-in through 2007. In 2008 they were bolt-in but I never tried swapping the rear assemblies.
Samurai Jack is offline   Reply With Quote
Old 04-28-2019, 01:55 PM   #4
jabrams
1.8L
Car: 99 Coupe Aspen, 98 Coupe BMP
Fav Mod: Spicy Cams
It is possible to replace the whole assembly "knuckle"
Try these guys.F&S Auto Parts - 888-372-8862 - Subaru Auto Parts Specialist
I purchased two used knuckles from them, hub and bearing included. Drove both for over three years with no problems.
jabrams is offline   Reply With Quote
Old 04-28-2019, 04:12 PM   #5
FryphaX
FryphaX's Avatar
Fav Mod: Registration!
Trader Rating: (4)
The 'difficult' way is just you know, the way.
No.
Also, No.
Also, No.
Similar Threads
Thread Thread Starter Forum Replies Last Post
GC Parts Extravaganza Oakos Automotive Vendor For Sale Classifieds - In Stock Items 113 12-15-2015 10:27 AM
Replacment Wheel Hub and Bearing Sets Z1 Performance Vendor For Sale Classifieds - In Stock Items 118 12-30-2014 11:13 AM
GoPro Hero 3 Camera Kits and Accessories IN STOCK at OAKOS Automotive!! Oakos Automotive Vendor For Sale Classifieds - In Stock Items 66 06-27-2014 11:48 AM
Repressing a new wheel bearing?? shagnscoob Suspension, Brakes, Rims & Tires 2 03-17-2014 09:09 PM
Wheel bearing replacement tool Dravenm4 DIY - How / To Installs 3 03-17-2010 06:42 AM
