ABS Light On Dash Came On - Subaru Impreza GC8 & RS Forum & Community: RS25.com
Old 11-18-2004, 03:01 PM   #1
RicanLynk
Trader Rating: (3)
Default ABS Light On Dash Came On
Hey whats up, i was driving today and my abs light came on on my gauge cluster, how the hell can i shut it off, im assuming its a trouble code, but my brakes worked fine and i activated my abs as werll and they are fully functional, anyone have any ideas onto what is wrong if anything is wrong at all?
RicanLynk is offline   Reply With Quote
Old 11-18-2004, 03:04 PM   #2
Yaz
Car: 1998 CW Integra Type R
i forgot how to do it but u have to scan the code,(it involved a connector under the dash and pins, u count how many times the light lights up and stuff) either way u need to scan the cose to find out whats going on
http://www.cardomain.com/id/yaz46<- sold, and will be missed -- 06 SI - 98 R
Yaz is offline   Reply With Quote
Old 11-18-2004, 06:56 PM   #3
RicanLynk
Trader Rating: (3)
yea well it doesnt flash or anything, as son as i turn ignition, it turns on, and when i start and stays on.
Old 11-18-2004, 08:00 PM   #4
TVA
There are two fuses under the dash that are ABS related. If either of them have blown, your ABS light will come on. Usually this deactivates the ABS system though (I've wired a switch to the primary fuse slot so I am able to deactivate my ABS at will). It is possible that one of your ABS sensors has gone bad, causing a light but still allowing the ABS to function. Easiest solution would be to replace the fuses (<$3.00) and check to see if the light is still one. If so, time for a new ABS sensor. ABS fuses should be able to be located on the label of the fuse cover in the dash. Hope that helps.
TVA
TVA is offline   Reply With Quote
Old 11-19-2004, 05:48 PM   #5
RicanLynk
Trader Rating: (3)
no blown fuses. most likely blown sensor
Old 11-19-2004, 07:26 PM   #6
pimptight2.5
I need money
pimptight2.5's Avatar
Car: 1998 sub 2.5rs WRB
Fav Mod: Sway Bar
Trader Rating: (9)
nop man you need to add brake fluid. It will do that if the fluid is low. Doese the light go on and off. if so that is what it is add fluid
HOLLA AT YAH BOY
pimptight2.5 is offline   Reply With Quote
Old 11-19-2004, 10:01 PM   #7
Yaz
the flid will make the brake light go on not abs
Old 11-20-2004, 08:39 AM   #8
WGNMATT
Default typo
I know te problem. It is moisture in the the abs sensor connector . it causes corosion and then blocks the signal which sets an OBD 2 trouble code which i can fix and reset. or you might heve his something and knocked a tooth off of one of the wheel speed sensor tone wheels which would also set an ABS code.
Im the man
WGNMATT is offline   Reply With Quote
Old 11-20-2004, 04:11 PM   #9
pimptight2.5
I need money
Fav Mod: Sway Bar
Trader Rating: (9)
Im the man
P.S. V-TEC ******
Dude you need to take f-ing n word off htis site. I n9or fond of that stuff evev if fromn a black dude. Yyu would be mad if sopmone her called you one. so don't go them a reason to use that word on this site.
HOLLA AT YAH BOY
Old 11-20-2004, 04:29 PM   #10
SoloImpreza
Car: 99 silv P1 look-a-like ej207
Fav Mod: Hair Dryer lookin thingy
Trader Rating: (5)
since we are doing requests, i am going to request that you edit that post so we can actually read it. a thug uh?
99 P1 twin, 16g powered V7 ej207
SoloImpreza is offline   Reply With Quote
