GD control arm bushings into GC control arms - Subaru Impreza GC8 & RS Forum & Community: RS25.com
Old 05-23-2011, 07:31 AM   #1
SIMER
Fav Mod: Stroked CDB + EJ207 heads
Trader Rating: (25)
Default GD control arm bushings into GC control arms
I have a GD crossmember with GC control arms. As some of you may know, the GC bushings on the control arm that mounts to the crossmember is narrower than the GD bushing. Therefore they must me shimmed with washers.
I don't feel completely comfortable with that set up, which brings me to making this thread. If I were to buy GD bushings, can I press them into my GC control arms?
I just wish the world was twice as big and half of it was still unexplored. STi_SIMER
SIMER is offline   Reply With Quote
Old 06-01-2011, 02:38 AM   #2
da5dime
Fav Mod: CA Legal 207 w/ 6 Gears
Trader Rating: (25)
I just bought a GD Hyperflex kit and the GD bushings will go right into the GC. They were a little tight but worked, so they might go in like butter on the GD crossmember!
Burzinski: Watch it! Stop donating to cancer research and "awareness"!
da5dime is offline   Reply With Quote
Old 06-18-2011, 12:43 PM   #3
2slo4u
needs more cowbell
2slo4u's Avatar
Fav Mod: Aebs sleeves & Holyheader
Trader Rating: (41)
How did you get the front control arm front bushings to fit? Supposedly they changed in 98? and are longer. I wanted to get poly bushings for my front control arms but they list them as 98-05. What changed on the front control arm in 98 that would make the bushings not work? I thought 93-01 non-turbo imprezas had the same exact crossmember and control arm measurements.
I've got a FEVER, and the only thing that can cure it is more WHP!!!
2slo4u is offline   Reply With Quote
Old 06-23-2011, 02:41 AM   #4
kay95
Car: 95 L, 96 OUTBACK
Fav Mod: p1 SUSPENSION
I dont think they changed. They should all be the same. I have a 95 and I am using the same part as a 2000 imp for the front control arm bushing. It fit no problem.
kay95 is offline   Reply With Quote
