Upgrading to 4/2 Pot Brake Calipers - Parts List - Page 4 - Subaru Impreza GC8 & RS Forum & Community: RS25.com
Old 12-02-2008, 05:37 PM   #31
zebro racing
Car: '98 2.5 RS
Fav Mod: my right foot
will any 03-07 wrx calipers swap direct (including: braket, caliper, rotor and pads)?
Vehicular manslaughter: it's what makes a Subaru, a Subaru. - FL4TFTW
zebro racing is offline   Reply With Quote
Old 12-02-2008, 07:30 PM   #32
stoke
project blackbird.
stoke's Avatar
Fav Mod: Prodrive'd EJ205
Trader Rating: (26)
For the fronts, yes. You can either use your RS front calipers with an 02-05 WRX caliper bracket, or you can swap the 4-pots from an 06/07, which bolt directly to the front hub.
The rears are more complicated. 06/07 WRX 2-pot rear brakes require either an 06/07 WRX backing plate, or an aftermarket adapter bracket. More information on this can be found in the first post. Stock WRX rear brakes should bolt right up, but I think they're identical to the RS brakes, so they won't make much difference.
ad astra per aspera
stoke is offline   Reply With Quote
Old 12-03-2008, 06:04 PM   #33
zebro racing
Car: '98 2.5 RS
thank you
Old 12-06-2008, 01:29 PM   #34
DvSkD4
Fav Mod: Subaru 4/2 Pots
Trader Rating: (5)
wow, its crazy how much lighter the rear calipers are than the fronts
DvSkD4 is offline   Reply With Quote
Old 12-06-2008, 01:39 PM   #35
stoke
project blackbird.
stoke's Avatar
Trader Rating: (26)
Yeah, I'm inclined to think they're aluminum. The fronts are definitely iron.
ad astra per aspera
Old 12-08-2008, 04:45 PM   #36
zebro racing
Car: '98 2.5 RS
has anyone run into brake bias issues? is stopping distance empirically shorterwith the 4/2 pot setup?
Old 12-08-2008, 05:28 PM   #37
Danny Boy
Fav Mod: No Cupholders
Trader Rating: (26)
Yes its shorter.
I have no brake bias issues. Seems very balanced.
Danny Boy is offline   Reply With Quote
Old 12-17-2008, 09:51 AM   #38
glenb1991
so what model cars can you do this on? i have a 1994 and it has drums in the back, is this useable on my car or is there another swap i would have to do?
glenb1991 is offline   Reply With Quote
Old 12-29-2008, 07:05 PM   #39
nivlem
1.8L
Originally Posted by jab06 View Post
Does anyone have the part numbers for the black calipers? I ordered the red ones and got them in today, but just really want black. Im not gonna paint calipers black when theyre factory painted already. If not im gonna just stick with the red ones.
I got my black ones here, http://www.subaruwrxparts.com/produc...ont-p-415.html
nivlem is offline   Reply With Quote
Old 12-29-2008, 07:14 PM   #40
stoke
project blackbird.
stoke's Avatar
Trader Rating: (26)
That's a really good question. I see you have a FWD L, and there are some differences between the AWD and FWD rear hub/suspension assemblies. I have seen some catastrophic failures when FWD is converted to AWD without using all the AWD components, which leads me to believe the differences are substantial. Therefore I would not recommend trying to swap your drums to 2pot rears unless you are switching to AWD, or at least to the AWD cars' suspension components in the back.
However, I expect the 4pot fronts should bolt right up to your front hubs. If you have a friend with an AWD car you may want to compare your front hub designs to see if they are identical.
ad astra per aspera
