Upgrading to 4/2 Pot Brake Calipers - Parts List - Page 23 - Subaru Impreza GC8 & RS Forum & Community: RS25.com
Old 06-15-2015, 02:44 PM   #221
alter_
2.7L
Car: 1998, RS, Rally Blue 2.0 EJ20K
Fav Mod: JDM EJ20k swap
is this possible?
alter_ is offline   Reply With Quote
Old 11-19-2015, 04:34 PM   #222
Temayville25rs
1.8L
Default upgrading
Im planning on doing this upgrade this winter as well.
My problem is i had 2 wheel bearings go out on the rear.
Me & my uncle started tearing it apart to find that everything is rusted to hell.
The rotors, calipers, hub, all the bolts & the backing plate. So im going to replace everything and upgrade my brakes at the same time.
Can anyone tell me if i buy the 4/2 pot upgrade for the front & rear, should i buy 00' hubs or do i need the 06/07 hubs for the front & rear.
And i would also like to upgrade my pads and rotors when doing this install.
I was thinking a slotted & drilled rotor with maybe some hawk pads. Can anyone point me in the right direction to a website where i can purchase pads & rotors that will fit with the 4/2 pot upgrade.
Thanks in advance
Temayville25rs is offline   Reply With Quote
Old 02-24-2017, 01:48 PM   #223
gmaxee
2.0L
Trader Rating: (3)
Bring this up from the dead. Sorry if i have missed some infos here. I recently just bought 4/2 pots. It just came with pads and calipers only. I searched but for some reasons i still have questions:
1. Front rotors were the same from 02-07 (if im not mistaken), so i bought centric rotors with part #120.47018 along with stoptech ss line with part #950.47004. The front pretty much plug and play. Were they the right part for the front one?
2. For the rears, which part # the rear backing plates. I checked with subarugenuineparts.com and i put 07 wrx tr. they gave me different part #s which was 26255AA061/71 than 26704FE080/90. Which one should i get?
3. For wheel bearing, should i get the 06/07 wheel bearings? Or my stock gc8 wheel bearing. I am using my stock gc8 hubs and knuckles.
4. Are Centrics with part #120.47025 correct?
5. Rear stoptech lines with part #950.47501 also correct?
Thanks in advance for any help
gmaxee is offline   Reply With Quote
Old 02-24-2017, 04:44 PM   #224
2slo4u
needs more cowbell
2slo4u's Avatar
Fav Mod: Aebs sleeves & Holyheader
Trader Rating: (41)
It is for my 95L, some people change theirs.
I've got a FEVER, and the only thing that can cure it is more WHP!!!
2slo4u is offline   Reply With Quote
Old 04-17-2017, 09:45 AM   #225
cdales91
1.8L
Car: '01 2.5rs w/ V7 EJ207
Just an update, You shouldn't have to shave down the kartboy adapters like you used to in the past. I installed mine a few months ago, and didn't have to. However, you still need to add a washer to the bolts it gives you, or else they will scrape the rotor in the rear.
cdales91 is offline   Reply With Quote
Old 05-22-2017, 03:11 PM   #226
koalorka
2.0L
Car: 1995 STi Version II
Trader Rating: (5)
Anyone having done this, did the parking brake parts from the old setup install directly into the backing plate of the 06 WRX or do I have to order a whole 06 WRX parking brake setup?
koalorka is offline   Reply With Quote
Old 05-31-2017, 12:27 PM   #227
koalorka
2.0L
Trader Rating: (5)
Bump.
