2001 2.5RS Front & Rear Differential Oil - Subaru Impreza GC8 & RS Forum & Community: RS25.com
Old 09-06-2019, 11:38 AM   #1
eye-m-hip
1.8L
Default 2001 2.5RS Front & Rear Differential Oil
I am going to change my front & rear differerntial oil on my 2001 Impreza 2.5RS (automatic transmission). Seeing that the rear differential on the 2001 RS has LSD, do I need a oil that is for LSD. Will I need the same oil for the front and rear or different for the rear seeing the rear has LSD. Thanks for your help.
eye-m-hip is offline   Reply With Quote
Old 09-06-2019, 12:44 PM   #2
FryphaX
FryphaX's Avatar
Fav Mod: Registration!
Trader Rating: (4)
You do need friction modifier. I use Motul Gear 300 Ls for the rear differential.
The front diff is supplied by the transmission lubricant. No need for friction modifier / Limited slip oil in the trans.
Old 09-06-2019, 07:12 PM   #3
silverton
Fav Mod: turrrrrbbbbooooo
I believe on the manuals the front diff is supplied with transmission oil, but on the automatics it is a separate unit with a drain and fill hole that seals with the front diff dipstick.
Here's the service manual page for AT front diff fluid replacement.
2001ImprezaGC-ATDiffGearOil.pdf - Google Drive
2001 RS+T - 2001 LGT
Old 09-10-2019, 12:16 PM   #4
00redOBS
Fav Mod: parking tickets
Trader Rating: (5)
The rear LSD is a Viscous unit, its sealed.
00redOBS is offline   Reply With Quote
