1998 Subaru 2.5RS Transmission + Rear Differential Oil Change - Subaru Impreza GC8 & RS Forum & Community: RS25.com
Old 03-21-2019, 02:05 PM   #1
Mrxwormxsayz
1.8L
Car: 1998 Subaru 2.5RS
Default 1998 Subaru 2.5RS Transmission + Rear Differential Oil Change
Looking to do a oil change on transmission and rear diff in my 1998 Subaru 2.5RS. The service manual states to "Replace the Gasket with a new one" in regards to the transmission fluid change and the differential "Always use new aluminum gasket" but doesn't have part numbers. Anyone know the part numbers I cant find it on Subaruparts or the service manual. I want to be sure I have everything before draining the fluids out.
Mrxwormxsayz is offline   Reply With Quote
Old 03-22-2019, 05:18 PM   #2
Skyfoogle
1.8L
Car: 99 2.5rs Coupe
I think its literally just an aluminum washer. You can go and get copper washers from advance auto or napa or whatever itll work the same. Also i wounld'nt use Subarus engine oil drain plug crush washers. I got a whole bag of them and and from my experience they leak oil. So i use a copper washer for that too
Skyfoogle is offline   Reply With Quote
Old 03-26-2019, 06:35 PM   #3
kay95
Car: 95 L, 96 OUTBACK
Fav Mod: p1 SUSPENSION
You can use copper however be aware of the galvanic corrosion that can happen given enough time. Probably nothing to worry about but that is probably why the OEM is aluminum.
Personally I dont change the washers. I just make the drain plugs tight and dont have leaks. If I do have leaks they are much smaller than the oil coming out from other parts of the engine because it has high miles. I am keeping the chassis from rusting
kay95 is offline   Reply With Quote
Old 03-27-2019, 08:16 AM   #4
Samurai Jack
1.8L
Car: 2002 WRX
Fav Mod: Enemy of Aku
For your rear diff, you can go here. Look at part # 10:
Differential for 1998 Subaru Impreza | Subaru Parts Store
Your rear diff cover * should * have both a drain and fill plug, but not all cars do. If it already has both, then you do not need a new rear diff cover gasket unless yours is leaking. Use copper RTV on the threads of the plugs when re-installing
For the transmission, automatic or manual?
If it's an automatic, make sure you change the panel filter as well.
There is no gasket for the pan to transmission for the automatic. You will need to use a proper RTV for that.
Samurai Jack is offline   Reply With Quote
Old 03-27-2019, 06:25 PM   #5
Mrxwormxsayz
1.8L
I got an email from an old vendor here in regards to a cocktail you run before draining unfortunately he didn't have any left but told me to run Dexron III ATF fluid for 30 minutes and draining while its warm to get rid of grinds. Has anyone done this for a 5 speed manual transmission before?
I picked up a bottle of Motul Dexron III to try out... I hope it doesn't harm anything.
So he told me to drop in half a liter in the transmission and drive it for about 30 minutes and drain it while warm for anyone out there wondering.
Similar Threads
Thread Thread Starter Forum Replies Last Post
FS (USA,CO): ACT clutch parts & ACT Prolite flywheel works on Impreza 2.5 RS, forester, Legacy, Ba winston84 Transmission & Drivetrain Parts For Sale 14 10-25-2013 07:13 AM
FS (USA,MI): 2004 Subaru Wrx. Sti block & 6 speed , Gt30r turbo, much more, clean! Subaru Powa Cars For Sale 39 01-30-2013 07:44 AM
Opinions: 2.5 vs. 2.2 nox General Subaru Discussion 25 02-21-2008 03:55 PM
Anyone Ever Notice... MotorCityRS25 General Subaru Discussion 16 09-09-2004 06:47 AM
