Transmission input shaft issue - Subaru Impreza GC8 & RS Forum & Community: RS25.com
Old 03-19-2019, 12:18 PM   #1
Fishstick919
1.8L
Car: 2001 Impreza 2.5RS
Default Transmission input shaft issue
So I'm swapping the engine from my Forester to my 01 2.5RS to get her running again and I ran into one issue. The trans on the Forester has a type of sleeve over the input shaft where the throwout bearing sits but the 2.5RS does not(the input shaft is also marred up a bit) and so the bearing doesn't fit correctly and can move around a lot. I've tried researching for that part but came up with nothing. What part is it? Can I swap it? Ideas?
Transmission input shaft issue-20190319_133438_1553022978320.jpg   Transmission input shaft issue-20190319_133419_1553023014662.jpg
Fishstick919 is offline   Reply With Quote
Old 03-19-2019, 01:43 PM   #2
johnxx
2.5L
Car: '96 OBS
Fav Mod: EJ204!
Looks like a snout repair kit / sleeve. I'm not sure if there's more than one kit available, but here's some info on the bearing for the Tranquil TSK1: Where to get new throwout bearing for TSK1 Snout Repair Kit
johnxx is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
Very dissatisfied with Supers587 JDM-Alex Member Reviews & Scammer Reports 463 09-29-2011 03:34 PM
Input shaft nut loose? kota62 Impreza L, LS, LX, Brighton, etc. 0 07-06-2009 12:49 PM
pilot, throw out, or input shaft bearing? Gooshin Transmission & Drivetrain 7 06-17-2009 10:22 AM
Choking at higher RPMs. JZ oo7 N/A Tuning 55 11-21-2008 11:39 AM
check engine light Josh Aydt General Subaru Discussion 9 12-28-2002 09:06 AM
