Transmission swap questions - Subaru Impreza GC8 & RS Forum & Community: RS25.com
Old 09-27-2018, 06:33 PM   #1
jeff6666p
Car: 98 impreza rs black
Default Transmission swap questions
Will the driveshafts from my 98 rs work with a 06 wagon wrx transmission and diff? Is the 06 wrx transmission stronger then the rs's since it came on a turbo?
jeff6666p is offline   Reply With Quote
Old 09-27-2018, 08:20 PM   #2
FryphaX
FryphaX's Avatar
Fav Mod: Registration!
Trader Rating: (4)
In the RS, yes it will. Yes it is.
FryphaX is online now   Reply With Quote
Old 09-29-2018, 07:57 PM   #3
jeff6666p
Thank you.
Old 10-11-2018, 11:10 PM   #4
jeff6666p
I just realized I'm not sure if I can jack the car up high enough to pull the trans. Does anyone know if 17inch's is enough
Old 10-12-2018, 07:41 AM   #5
postwarart
According to this diy you need 18 inches
DIY: Clutch Replacement Pictorial
postwarart is offline   Reply With Quote
Old 10-12-2018, 09:52 AM   #6
yarrgh
Car: Black 2001 RS
Fav Mod: larger rear brakes
You can always use blocks of wood to set the jack stands on as well as help the jack. Just make sure they're sturdy.
Who is John Galt?
yarrgh is offline   Reply With Quote
Old 10-16-2018, 04:24 PM   #7
Alxndr13
1.8L
Car: 2007 Subaru Impreza 2.5l
Fav Mod: short shift
When I took mine out, it was on a QuickJack, advertised to have 18" lift. It was tight, but I used a motorcycle-jack, not a compact trans-jack. I would think 17" would be enough.
Alxndr13 is offline   Reply With Quote
Old 10-16-2018, 10:40 PM   #8
jeff6666p
Thank you
Old 02-21-2019, 04:32 PM   #9
jeff6666p
I just realized the rs has stub axles and the wrx are male. From what I read the abs plugs on the wrx are different. Can the plugs be swapped over if so how do I remove the plugs?
Will the gd axle work fine with my gc knuckles? the gd ones have tone rings.
