JDM 6 Speed on the Highway - Subaru Impreza GC8 & RS Forum & Community: RS25.com
Old 05-21-2019, 02:59 PM   #1
Barelyboosted
1.8L
Default JDM 6 Speed on the Highway
So I have a 03 sti 6 speed sitting in my garage and I'm curious about the shorter gearing on the highway. I'm not a fan of high rpms when cruising on the highway. One of my cars is at 4000 at 75mph and I'd like to avoid that if possible.
I drive a ton for work across the states and would like it to be nice to drive around in. What are the shorter gears like and how much shorter they are compared to the USDM 6 speed
I was also considering going with some longer gears (longer than usdm) for it if I cant do the short ones. I've seen longer 5th and 6th gears which sound very nice. If I were to get longer gears what else other than the 5th and 6th should i upgrade that are weak in this trans?
Barelyboosted is offline   Reply With Quote
Old 05-22-2019, 10:50 AM   #2
FryphaX
FryphaX's Avatar
Fav Mod: Registration!
Trader Rating: (4)
Look up the gear ratios based on the trans code and do the math.
Old 05-22-2019, 10:56 AM   #3
equinox92
They call me Garrett
equinox92's Avatar
Fav Mod: Park Bench
Trader Rating: (53)
+1 for trans code + gear ratios + math.
The early JDM 6 speeds are pretty short.
Tuned Detroit - Automotive Blog, check it!
equinox92 is offline   Reply With Quote
Old 05-22-2019, 11:01 AM   #4
SoCoNoHa
2.7L
Fav Mod: Anything custom
When you figure out your gears and tire size, plug em in here:
Subarugears
Edit: here's there trans chart:
GearHack: Revision: Subaru Transmission Chart
With my slightly smaller 24" tires (205/50r16) I'd be spinning 3454 rpms at 75mph in your transmissions sixth gear.
97 LGT / 92 SVX / 95 GM∆
SoCoNoHa is online now   Reply With Quote
Old 05-22-2019, 11:37 AM   #5
johnxx
Car: '96 OBS
Fav Mod: EJ204!
If anyone finds this thread and is looking for a transmission not on that list: https://www.rallispec.com/downloads/...art_Public.pdf
johnxx is offline   Reply With Quote
Old 05-29-2019, 05:14 AM   #6
02OBS25L
1.8L
Car: 07OBS
Fav Mod: All of em'
The stock Imprezas and Foresters I believe have .390 final ratios which will raise your top end (lower your cruising rpm) something to ponder.
02OBS25L is offline   Reply With Quote
Old 05-29-2019, 06:19 AM   #7
Samurai Jack
1.8L
Car: 2002 WRX
Fav Mod: Enemy of Aku
Take your current rpm values for the transmission in your car and add 200 - 250 RPMs.
That was what happened when I went from an 02 OEM 5MT WRX to an 02 OEM JDM 6MT ... AND from a 3.54 Final Rear Diff to a 3.90 Final Rear Diff.
Remember you need to match the transmission to the rear diff or you will damage the transmission.
Samurai Jack is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
Equinox's RBP V8 EJ207 STi Swapped RSTi - Twinscroll Braps Inside equinox92 Members' Journals 2485 Yesterday 09:39 AM
My 2000 Silver STi Coupe RancerEvorution Members' Journals 122 02-07-2018 05:15 AM
01 STM RS - JDM STI Type-R clone, EJ257, Brembos, 6MT impreza_GC8 Members' Journals 20 05-05-2017 01:16 AM
jdm wheels , large inventory just landed .....ce28 just added jdm advance motor import Vendor For Sale Classifieds - In Stock Items 15 10-17-2015 09:56 AM
[SOLD] THE '98 RS Coupe w/ JDM v.8 swap John2.5RS Cars For Sale 46 05-31-2012 10:20 PM
