06 wrx swap fuel lines - Subaru Impreza GC8 & RS Forum & Community: RS25.com
Old 09-07-2019, 11:29 PM   #1
jeff6666p
Car: 98 impreza rs black
Default 06 wrx swap fuel lines
I'm trying to install the feed line but there isn't much room between the damper and the fuel filter. Is it ok to remove the fuel dampers? If not could I remove the oem hoses and just use regular fuel hose.
jeff6666p is offline   Reply With Quote
Old 09-09-2019, 10:45 AM   #2
breadandbutter
Fav Mod: Shop to work in
Yes and no, I do not believe there are many adverse effects besides turbulence in the fuel flow to the injectors possibly effecting spray patterns. Yes you're fine to run without them its not going to hurt anything. No, you should make them work because factory engineering > some guy with bread in his name on the internet.
breadandbutter is offline   Reply With Quote
