Help with oil temp and oil pressure gauge - Subaru Impreza GC8 & RS Forum & Community: RS25.com
Old 10-29-2018, 06:48 AM   #1
Maverick15
1.8L
Default Help with oil temp and oil pressure gauge
Hi so I’m a subi newbie wanting to install a oil temp gauge along with a oil pressure gauge on a N/A ej25d and I’ve looked around and determined that I’m probably going to use the front oil gallery with a t fitting and I’ll put the oil pressure sensor and keep the dummy light on that t but I don’t know where would be the best for the temp sensor and everything I would need to purchase to make this happen, I know I’ll probably need adapters and probably a relocation kit. so I’ve come to ask for assistance and links to the things I need to buy to make it work, links would be great, If needed I can provide more information if need be first time posting and first time doing this install so I’ll probably add more questions
Maverick15 is offline   Reply With Quote
Old 10-29-2018, 06:57 AM   #2
scruff3333
scruff3333's Avatar
Fav Mod: broken motor
Trader Rating: (10)
Oil Temp Sensor Location Discussion - NASIOC
Here's a good read. Two VERY informed individuals and there dif looks on your subject.
Nerds get to go to the moon
scruff3333 is offline   Reply With Quote
Old 10-29-2018, 08:39 AM   #3
Maverick15
1.8L
Thanks so I’m probably going to continue with putting the pressure and the dummy light on the top front gallery under the alternator and the temp on the rear top gallery what should I get to properly have all the adapters and to make sure everything has proper clearance
Old 10-29-2018, 08:42 AM   #4
Maverick15
1.8L
Also if all else fails I may also just put both the pressure and temp on the front on a t
Old 10-29-2018, 09:17 AM   #5
scruff3333
scruff3333's Avatar
Trader Rating: (10)
There's also the other port on the back of the block passenger side by PVC. Thats were I'll stick my oil temp. And like you said just T of the front. The dummy light wont shine if you just unplug it. It's more of a replace bearings light, only goes off a 2 psi or something ridiculous. Or tap back of a head little more envolved.
Old 10-29-2018, 10:00 AM   #6
Ted
2.5L RS-T
Trader Rating: (3)
I agree with scruff the dummy light is less than useless. The engine is toast or at least deprived from oil if that comes on. I removed mine and forgot about it.
A three syllable word for thoughts too big for small minds
Ted is offline   Reply With Quote
Old 10-29-2018, 10:04 AM   #7
scruff3333
scruff3333's Avatar
Trader Rating: (10)
Just to add, you can also get oil temps from tapping the oil pan, good location. They also make oil pan plugs that you can install a temp probe in. I personally think that's my least favorite option.
Old 10-29-2018, 10:42 AM   #8
Maverick15
1.8L
That’s probably what I’m going to do pressure up front temp out back how’s the clearance on it and aren’t the threads a pain to find adapters for that’s the thing I want to make sure I’ll have everything to plumb it up in one go because the folks at the hardware store know me by a first name basis lol
Old 10-29-2018, 06:23 PM   #9
Maverick15
1.8L
Correct me if I’m worn my but isn’t it a 1/8 npt thread for both galleries
Old 10-29-2018, 09:43 PM   #10
FryphaX
FryphaX's Avatar
Fav Mod: Registration!
Trader Rating: (4)
Originally Posted by Maverick15 View Post
Correct me if Iím worn my but isnít it a 1/8 npt thread for both galleries
After using the correct adapter plug. Dig through my member journal. Part numbers and sources are in there.
