Water Injection? - Subaru Impreza GC8 & RS Forum & Community: RS25.com
Water Injection?
Old 02-13-2004, 08:17 AM   #1
1SpEeDyRS
Default Water Injection?
has anyone had any experience running water injection?
-1SpEeDyRS
1SpEeDyRS is offline   Reply With Quote
Old 02-13-2004, 06:04 PM   #2
b-o-b-s
i have never done it but some guys i work with use to do it to old muscle cars.
b-o-b-s is offline   Reply With Quote
Old 02-15-2004, 05:37 AM   #3
1SpEeDyRS
anyone else? - 1SpEeDyRS
Old 02-15-2004, 02:32 PM   #4
HondaH8er
13 Years of RS
HondaH8er's Avatar
Car: 2005 Toyota Corolla :(
Supposed to work well if you are running high boost. I'm sure someone has mentioned this before, but you should probably read Corky Bell's book "Maximum Boost", it's supposed to be really good. I'm pretty sure he covers water injection in there somewhere. I haven't read it yet, but I'll get to it eventually.
When we race, Focus on my tail lights....
HondaH8er is offline   Reply With Quote
Old 02-15-2004, 03:48 PM   #5
Skully
Skully's Avatar
Car: 2013 SWP BRZ, 04 STM STI
Fav Mod: boost
Trader Rating: (5)
i have never heard of this.. if anyone can post a link on info.. i want to read on it.
98 RBP RS-T
Skully is offline   Reply With Quote
Old 02-15-2004, 03:58 PM   #6
N/A
Look up Aquamist products then cause they are one of the few well known companies who do the water injection. You could also look into variable propane injection as well. Both will have the same effect which is lower the chances for detonation. The water cools the cylinders where as the propane is simply adding more fuel to lower the chances of detonation.
N/A is offline   Reply With Quote
Old 02-15-2004, 06:39 PM   #7
1SpEeDyRS
basically it injects a extremely fine jet of water in to the intake cahrge cooling the charge. there are a couple reasons for spark knock. high intake charge temp( a big problem with boost), to lean a mixture, too much timing. since i'm running 9psi with a supercharger, i cant really intercool it, and instead of retarding timing, i'm going to run water injection to take the palce of an intercooler. i was just wondering if anyone had any experice?
-1SpEeDyRS
Old 02-15-2004, 07:10 PM   #8
Skully
Skully's Avatar
Fav Mod: boost
Trader Rating: (5)
yeah.. i read alot on it.. seems like a sweet way to solve a few problems.. if you do get one.. hope you dont have any problems with it. good luck!
98 RBP RS-T
