Led cluster question - Subaru Impreza GC8 & RS Forum & Community: RS25.com
Old 03-28-2019, 06:45 PM   #1
jeff6666p
Car: 98 impreza rs black
Default Led cluster question
If I only change the turn signals in the cluster to led will I get hyperflashing?
jeff6666p is offline   Reply With Quote
Old 03-28-2019, 07:26 PM   #2
FryphaX
FryphaX's Avatar
Fav Mod: Registration!
Trader Rating: (4)
In my experience, No.
Old 03-30-2019, 01:07 PM   #3
jeff6666p
Thanks
Old 04-01-2019, 09:42 PM   #4
jeff6666p
I'm disappointed with how the leds came out There's hot spots and they're too dim.
Old 04-02-2019, 01:23 AM   #5
johnxx
2.5L
Car: '96 OBS
Fav Mod: EJ204!
I've been looking at doing something similar. Would you be willing to share photos and maybe a picture of the LEDs so I at least know what won't work that well? I imagine part of the issue is that the "light pipes" in the cluster are designed with the 360 degree illumination of an incandescent bulb in mind. Depending on where the LEDs are pointing, you'd get hot spots and dim spots.
johnxx is offline   Reply With Quote
Old 04-02-2019, 02:57 AM   #6
jeff6666p
I used these bulbs below. In pictures it came out perfect and bright but in real life it's only a tiny bit brighter then the old bulbs. at 0-1k and at 7k it's brighter that's where the hot spots are. The speedo was balanced but still only as bright as the regular bulb. The top of the fuel gauge has a hot spot and the temp gauge seems like it's almost slightly dimmer the the stock bulbs. The clock is really bright and doesn't dim anymore when the when the headlights are on. I also changed the turn signals and high beam bulbs. They are really bright.
During the day when the lights on full brightness I can't see the lights from the main section. everyone in the forums have the 99+ with the 74 bulbs in pictures they are bright and can be seen durning the day. I have a v4 cluster the 194 are my main bulbs which are supposed to brighter but they suck.
74 LED Bulb - 3 SMD LED - Miniature Wedge Base | Super Bright LEDs
194 LED Bulb - 5 LED - Miniature Wedge Base | Super Bright LEDs
Old 04-02-2019, 06:47 AM   #7
FryphaX
FryphaX's Avatar
Trader Rating: (4)
I used green LEDs from Amazon for my cluster. Came out decent.
https://www.rs25.com/forums/search.php?searchid=6367327
Old 04-02-2019, 11:02 AM   #8
George.of.the.Jungle
Baby❤Daddy
George.of.the.Jungle's Avatar
Fav Mod: BOOOOOOST!!
Trader Rating: (75)
i used blue..
Old 04-02-2019, 11:12 AM   #9
FryphaX
FryphaX's Avatar
Trader Rating: (4)
Damn, that blue looks good.
Old 04-02-2019, 01:51 PM   #10
jeff6666p
In real life it's as bright as the temp gauge and the temp gauge looks dimmer. This is full brightness
Similar Threads
Thread Thread Starter Forum Replies Last Post
DIY: LED Cluster Color Change using LED Strips. cang720 DIY - How / To Installs 11 09-06-2018 11:12 AM
Instrument cluster swap question chefeagles General Subaru Discussion 2 06-22-2015 11:33 AM
DIY: How to wire up a 98 cluster in a 93-97 my3awds DIY - How / To Installs 27 03-02-2011 12:17 AM
YES another LED Question HopesAndDreamsRacing Interior & A/V 14 11-14-2006 10:09 PM
Gauge Cluster Question scoobyru00 ECU & Electrical Modifications 0 11-09-2006 01:58 PM
