sti steering wheel - Subaru Impreza GC8 & RS Forum & Community: RS25.com
sti steering wheel
Old 06-19-2007, 08:39 AM   #1
mikeyp5284
Car: 13 Impreza
Fav Mod: the Lowered Insurance mod
Trader Rating: (18)
Default sti steering wheel
just wondering.... when swapping the sheel from my 2001 RS to one from a 2006 sti, what do i need to make the airbag functional?
TIA
Mikey
mikeyp5284 is offline   Reply With Quote
Old 06-20-2007, 07:15 PM   #2
biGshizzle79
Car: 00 2.5 RS BRP Sedan
Fav Mod: chop, drop, n channel
Trader Rating: (6)
I would hope the clips should mate up properly...
If not, I'd definately leave it alone...
airbag stystems are NOT to be modified, only defeated and turned off if needed
Learn how to weld, you ricer!
biGshizzle79 is offline   Reply With Quote
Old 06-21-2007, 09:34 PM   #3
poleboy90
Trader Rating: (54)
Does anyone what needs to be done to make the airbag and cruise control work? Does everything fit right?
poleboy90 is offline   Reply With Quote
Old 06-22-2007, 10:33 AM   #4
poleboy90
Trader Rating: (54)
Anyone know? Should this be the same as the 04 STi wheel? Do you need to swap airbags and cruise control stalks from the RS wheel? Will the horn work?
Old 06-22-2007, 11:09 AM   #5
XyKoX
Car: 2001 Impreza 2.5RS SRP
Trader Rating: (3)
Horn will work, cruise will need a little modified IIRC. But you'll need the clock spring to make the airbag to work.
If you want a GC8, go to japan. If you want a GC8 style, then get a sedan.
XyKoX is offline   Reply With Quote
Old 06-22-2007, 12:00 PM   #6
poleboy90
Trader Rating: (54)
I heard you can swap the airbag explosives from the RS wheel to the 04 STi wheel? Does this hold true for the 06 STi wheel? Would splicing the wires to the RS plug be better?
Old 06-22-2007, 12:09 PM   #7
deadchip
deadchip's Avatar
Car: 00 V7 RSTi racingbrake4pots
Fav Mod: JDM V7 STi engine swap
Trader Rating: (7)
Enquiring minds what to know!!! About the airbag thing.
"What's behind me, don't matter!"
deadchip is offline   Reply With Quote
Old 06-22-2007, 01:31 PM   #8
mikeyp5284
Car: 13 Impreza
Trader Rating: (18)
i was told that all you need for the airbag to work is to swap the clockspring from the rs wheel to the new wheel. not too sure about the cruise.... i'm doing this swap in a week and i'll let you guys know what it requires.
