FS (USA,WV): Hawkeye Part Out - 6466, ETS, IAG, Mishimoto, Grimmspeed, Radium, HKS, Prosport, more - Subaru Impreza GC8 & RS Forum & Community: RS25.com
Go Back   Subaru Impreza GC8 & RS Forum & Community: RS25.com > > >
Old 08-02-2018, 09:49 AM   #1
Gixxer
1.8L
Trader Rating: (12)
Default Hawkeye Part Out - 6466, ETS, IAG, Mishimoto, Grimmspeed, Radium, HKS, Prosport, more
06 WRX TR - 133k miles on body less than 5k on go fast parts. I bought it for the transmission swap so the rest is for sale besides the short block is blown up.
Located in Fairmont WV & shipping isn't a problem just message me for a quote. If you want pictures of a certain part just ask.
Engine & Drivetrain
DW300s $85 each
Water Pump $25
Oil Pump $50
Front WRX Axles $75 each
5x100 Kunckles $75 each
06 STi 5x114 Knuckles $100 each (34k miles)
06 STi Rear Axles $100 each (34k miles)
Rear Crossmember $100
Rear Diff Subframe $50
Transmission Subframe $50
Trailing Arms $40 set
Oil Fill Neck $10
Fuse Box $40
Power Steering Reservoir $20
Power Steering Reservoir bracket $10
Clutch Master $50
Brake and Clutch Pedal Assembly $100
ABS Module $50
Proportioning Valve $20
Exterior SGM Paint Code: 26D
Rear Bumper Beam $100
Doors $200 each
Driver Fender $150
Trunk & Wing $200
Wiper Arms $30
Wiper Motor & Linkage $40
Wiper Cowl $25
Exterior Trim/Moldings $20+
Prosport Boost Gauge $50
Seat Belts $40
Dash $100
Dash Bar $50
Gauge Cluster $90
Heater Core $70
Steering Wheel $70
Steering Column $100
Headlight Switch $25
Wiper Switch $25
Hazard Switch $15
Window Switches $10 each
Switch Blanks $5
Dome light $20
Plastic Interior Pieces $10+
Gixxer is offline   Reply With Quote
Old 08-04-2018, 07:34 AM   #2
Gixxer
1.8L
Trader Rating: (12)
Bump.
Old 08-05-2018, 09:38 PM   #3
arestanz
1.8L
How much for the hvac bezel and controls with cables shipped to 95687?
arestanz is offline   Reply With Quote
Old 08-06-2018, 08:08 AM   #4
Gixxer
1.8L
Trader Rating: (12)
PM coming your way
Old 08-06-2018, 01:04 PM   #5
Combat Chuck
Fav Mod: EJ255 swap!
Trader Rating: (43)
PM'ed.
Every time a brotato wrecks a WRX, a GC gets its wings.
Combat Chuck is offline   Reply With Quote
Old 08-06-2018, 04:38 PM   #6
Gixxer
1.8L
Trader Rating: (12)
Originally Posted by Combat Chuck View Post
PM'ed.
replied
Old 08-08-2018, 09:53 AM   #7
Gixxer
1.8L
Trader Rating: (12)
bump.
Old 08-10-2018, 07:29 AM   #8
Gixxer
1.8L
Trader Rating: (12)
OP Updated
Old 08-10-2018, 02:53 PM   #9
AsMadAsHatter
1.8L
Mishimoto Radiator $230
Or any of the suspension ....
Any chance this will fit a 2000 subaru RS?
AsMadAsHatter is offline   Reply With Quote
Old 08-10-2018, 08:12 PM   #10
Gixxer
1.8L
Trader Rating: (12)
The radiators are different between GCs and GDs so the mishimoto will not work. Some suspension stuff will swap over but what were you thinking about getting? Pretty sure the rear sway bars are the same but the fronts are different. The front struts are interchangeable but the rears have different top hats. You can modify your mounting holes to get them to work: GD Suspension on a GC - NASIOC
