Dan7140's "T-Minus" Track Car Build - Subaru Impreza GC8 & RS Forum & Community: RS25.com
Old 09-22-2016, 10:00 AM   #1
Dan7140
Impreza Actual
Fav Mod: 13 Subarus deep...
Default Dan7140's "T-Minus" Track Car Build
Hi guys! I am back with another Subie. My old thread can be found here. The goal of this new car is to get it ready for Auto-X over the winter and then build it over time for the road course as well.
A very good friend of mine whose username on here is Snowbum has owned it for probably the last ten years or more. It is a 2001 2.5RS with 117000 miles. It is painted Porsche Seal Grey 6B5.
The rust on the outside and the dings and scratches here and there aren't the greatest, but inside the car and underneath it is in very good condition.
I need to start recording my weight and what I have done to get there:
Currently weighs 2620 lbs with a 1/2 tank of gas - 1640 front and 980 rear. (even lighter now, will weigh later)
Antigravity 3 lb battery
DSS Carbon Fiber Driveshaft
flat aluminum panel trunk with spare tire tub cut out (wasn't even heavy )
SSR type Cs
No sound deadening but has full interior put back in.
No A/C - completely deleted everywhere even in heater core area
No airbags, NRG steering wheel
lightweight crank pulley
ACT lightweight flywheel
Gutted sound deadening from firewall to trunk, interior is pretty much mocked up but bolted down.
Sunroof motor assembly removed and sunroof is bolted in place.
Aluminum GD front control arms
Intake manifold and heads are ported/gasket matched
Reversed intake manifold for less FMIC piping
No IACV and very trimmed/ported throttle body.
Side impact bar delete
Both bumper beams are pretty much non existent
Only one electric fan, Mishimoto shroud and second fan was too much.
ISC Coilovers
No radio
No speakers
No fogs
Current upgrades: (Installed as of now)
Engine
Hydra Nemesis v2.5 - Tuned by RS Motors 15 PSI
EJ22E stock shortblock ~90-100k miles on it (welded turbo oil return in pan)
2.5RS SOHC heads Ported and Polished
Reversed manifold
NGK BKR7EIX-11 (1-step colder plugs, can't remember what I gapped them too, should be around .028-,032)
ARP Head studs
10mm oil pump
Supertech Dual Titanium Valvesprings
Delta Cams (2000 on intake and 1000 on exhaust) .006 in .008 ex
FP Evo3 16G Turbo - AN coolant/oil lines
Modified Grimspeed catless uppipe custom rotated
CXRacing FMIC
Trust/Greddy Front Mount Oil Cooler with Earl AN-10 lines and Earls swivel fittings
Mishimoto aluminum rad/shroud/ electric fans - aluminum sheet riveted in to fill in side air gaps
Silicone hoses
Forge BOV FMDVSUB03
3" straight TBE bellmouth downpipe with Magnaflow muffler
Kartboy hangers
Grimmspeed AOS
Lightweight Crank pulley - not dampened
Walbro 255lph pump
Aeromotive RRFPR
Turbosmart Manual Boost Controller
Aeromotive WRX fuel rails
750cc Modded injectors - Basically super soakers. I will have to get injectors that can atomize.
Parallel fuel lines with AN fittings
JDM coolant in-fender overflow tank
Antigravity THREE POUND Battery AG-1201 12 Cell
DEI 2" x 35ft Titanium Exhaust Wrap
PTP Turbo Blanket Heat Shield - Lava
Drivetrain
Version 6 STi RA V-Limited 5spd DCCD Helical front diff (TY754VB1EA) Up to 47% wider teeth and steel shift forks instead of aluminum
Group N transmission mount
Whiteline Transmission Crossmember Bushing
Whiteline Diff Support Outrigger Bushings (destroyed these trying to press in, went with Powerflex PFR69-118 Instead)
Whiteline Rear Trailing Arm Front Bushing Kit
Whiteline Rear Trailing Arm Lower Rear Bushing
Laile Beatrush rear diff brace
Laile Beatrush forged pitch stop mount
Cusco hyper gum shift linkage bush
DSS Carbon Fiber Driveshaft SUSH1-C
R160 SureTrac rear diff
05 Forester XT rear axles (were the same length - so confused)
ACT SB9-HDSS Clutch
Kartboy Short shifter
Suspension
ISC N1 coilovers 10K Front 8K Rear Track valving with thrust bearings
GD STI front lower control arms
M4iF Fender Braces/Cowl Stays
Whiteline Rear Lateral Links for GD STI width
Whiteline Anti-lift Kit
Whiteline Front Lower Control Arm Bushing
Whiteline Steering Rack Bushings 25MM
Whiteline Tie Rod Ends - Roll Center Adjustment
Whiteline Lower Ball Joints - Roll Center Adjustment
Whiteline Subframe Locking Bolts
Mines H-Brace
20mm front swaybar 05 WRX
Turbo front subframe
WRX year? 17mm rear swaybar with VW solid endlinks
Wheels/Tires/Brakes
SSR Type C 17x8.5 +48
Bridgestone Potenza RE-71R 255/40/17
Cadillac CTS-V Brake calipers and adapters
DBA 4000 rotors
Hawk HPS pads
ATE type 200 fluid
SS Brake lines
Brake master cylinder brace
Ebay flares riv-nutted on(2 sets of fronts all the way around)
STi Fog covers
V6 style front lip
Rally Armor mudflaps
JDM Rear bumper
JDM tails
JDM rear spats
Shaved door trim
Cracked "carbon" gauge pod and some gauges Boost/Oil Pressure/AFR/Fuel Pressure - will be tidying/refreshing that) But the interior is mint!
04/05 WRX Black seats
Fluids
Rotella T6 in engine
Regular 50/50 in cooling system
Extra S in transmission
Redline 75/90 and a little bit of Extra S in the rear diff
For me:
I didn't take too many pics before tearing into things I wanted to get done.
Mr. Earl loves this car so much for some reason!
I kill threads.
Dan7140 is offline   Reply With Quote
Old 09-22-2016, 10:07 AM   #2
Dan7140
Impreza Actual
Starting right away I took a look at the oil cooler since I wanted to put mine on instead.
Turns out it was an oil "fooler" (check the missing lines where you see threads). I remembered Snowbum got rod knock when he was running a 22T block with forged internals (while on the dyno tuning!), and didn't want to reuse the oil cooler since all the metal shavings made a home in there. This car has no factory heat exchanger above the oil filter so I will use my Trust/Greddy one with the built in thermostat and oil pressure/temp sensors instead:
The front swaybar clunked so I bent the subframe plate back into shape and removed the 5 lb metal chunk above it that the JDM cars don't have:
I started chipping rust - this is the inside of the rear left fender:
I want to go with a sleek look and I immediately took off the trunk/wing combo to sell. I will post a thread here and CL. I am buying an L trunk in 2 days and I put my old L hood on in the meantime:
I kill threads.
Old 09-22-2016, 10:37 AM   #3
George.of.the.Jungle
Baby❤Daddy
George.of.the.Jungle's Avatar
Fav Mod: BOOOOOOST!!
Trader Rating: (75)
first!!
Old 09-22-2016, 10:49 AM   #4
Dan7140
Impreza Actual
Hi GOTJ
I forgot to mention I am still trying to get my other car back (the white V4 swapped one). I have time now BMW is also for sale. I really don't care if it doesn't sell though, I LOVE that car.
I kill threads.
Old 09-22-2016, 05:40 PM   #5
Dan7140
Impreza Actual
So apparently the car has an oil leak coming from the rear of the oil pan. This is not an easy place to get to if you don't want to pull the motor.
I pulled the 2 14mm nuts holding the engine mounts to the subframe and also removed the tranny pitch mount and hoisted the engine up. I had to loosen the radiator as well so I didn't rip the lower rad hose off.
This is the gap I was left with:
^ Do you think that dent is affecting the oil pickup?
I broke the bolts loose with a 10mm socket and had a TON of help by using a flexible screwdriver twisty bendy rod thingy. Thank you Subaru for putting Phillips slots on those bolts!
Voila!
I had already loosened the dipstick tube from the top so I could wiggle it around and fandangle it out of there.
Cleaning the dirty pan:
Nice job welding an oil return line from the turbski:
By the way, are all RS pans silver??? ^ I've only ever seen black oil pans on Subarus, both turbo and non.
All clean!
I started chipping away at some of the rust. I have repaired rusty fenders a few times now, this should be a breeze. My initial plan was to get the sheetmetal flares of Ebay and go wider STI suspension links and wider wheels, but this car ended up being in way better shape than I figured. Now I think I will fix it to "factory spec", and if needbe I can always go wider in the future.
^ From the door trim removal :sigh:
I kill threads.
Old 09-23-2016, 05:16 AM   #6
jdm25rs
10 years in the game
Fav Mod: 26+ mpg
Trader Rating: (6)
Looks like it might be porsche seal grey.
Bye RS, bye wagon, bye RS again, bye hawkeye.....hello rear wheel drive Subaru!?!?
jdm25rs is offline   Reply With Quote
Old 09-23-2016, 05:19 AM   #7
Dan7140
Impreza Actual
Sweet thanks for that man. I don't know if it will stay this color or not when I do the body work. I mean it's a nice color, and would be easier since I don't have to do the door jambs/trunk/core support.
I kill threads.
Old 09-23-2016, 07:34 PM   #8
Dan7140
Impreza Actual
I sold the trunk/wing and immediately after went and picked up the L trunk. Man does it not fit for ****...
Sigh, I guess I will hit up some yards this weekend. I hope the rain lets up.
I kill threads.
Old 09-24-2016, 05:20 PM   #9
Dan7140
Impreza Actual
I got the Permatex Red to do the oil pan and started cleaning the bolts. I didn't take pics after the bolts were cleaned:
Time to get the bigger oil cooler mounted:
I ended up using a totally new mount:
Not too bad:
I took out the "broken" oil pressure sending unit and the T-fitting in the factory oil pressure hole broke off:
I replaced it with my other one even though it turned out to be a bad gauge:
Soldered the wires for the new pressure sending unit. I had to use both sandwich adapters sadly:
T6 changed their look. I heard soon they are changing the formula and it won't be good for Subies anymore.
I kill threads.
Old 09-25-2016, 06:04 PM   #10
Dan7140
Impreza Actual
So the oil lines for the oil cooler decided to assplode when I went for a test cruise. It took almost a gallon of backup oil I brought with to get me home. I wasn't even that far away. Lol luckily no harm just oil ALL over the place
I ordered new braided line, and will post pics once it's here.
I kill threads.
