Boobaru2: Betty White? So much for not being OCD again... - Subaru Impreza GC8 & RS Forum & Community: RS25.com
Old 11-19-2015, 05:15 PM   #1
BettyblueRS
I ❤ BOOBIES
Fav Mod: por15
Trader Rating: (25)
Default Boobaru2: Betty White? So much for not being OCD again...
Welcome to my journey of ruining my RS sedan, bit by bit.
Most recent look:
Parts list:
Engine/Turbo/Exhaust:
2005 STi EJ257 + ECU
V3 Cobb AP
TGV Deletes
Killer B Oil Pickup
DW850cc injectors
Grimmspeed EBCS
Koyo Radiator R2218 w/ slim fans
DW300lph fuel pump
2005 STi steering rack (modified ujoint to mate STi rack to RS column)
catch can from JEGS
Group N motor mounts
Custom TMIC
Custom intake to FP 84mm turbo inlet
FP HTA 71 Turbo w/ 84mm compressor port, ported and coated turbine housing+turbo blanket
Tial 44mm External wastegate
Cobb downpipe (originally catted; gutted and flex pipe added+hi-temp coating)
Custom 3” aluminum CBE
Transmission:
2005 STi 6 speed trans, driveshaft, rear diff, axles, 5x114.3 hubs
ACT Clutch
OEM STi flywheel
Cobb short shifter
Cobb/Torque Solutions shifter bushings
DCCDPro Spiider w/ cluster display and OEM controls
Suspension/Bracing:
RCE Tarmac 2 Coilovers (500/400)
Vorshlag Camber Plates
Whiteline camber bolts
2005 STi front and rear subframes, T brace
2005 STi front alum control arms, rear alum lat links, rear trailing arms
2005 STi front and rear sway bars+endlinks
M4iF Fender Braces
Torque Solutions rear diff brace
Brakes:
non-abs brake master, hard lines, prop valve
Centric non-abs 1 1/16 brake master cylinder
2005 STi Brembo brakes
DBA 4000 rotors
Hawk HP+ pads / swapping in Stoptech street performance pads
Goodridge ss lines
Interior:
Corbeau Forza FIA (driver), Corbeau Fx1 Pro (passenger) w/ Corbeau rails and double locking sliders
STi Drive by wire pedal w/ adapter plate
NRG gen 3 hub + quick release
Sparco leather L360 flat bottom wheel
JDM Ver 5/6 cluster w/ DCCD display
STi Titanium shift knob
LHD airbag delete
Exterior:
Carbon hood
MRT high rise scoop (hydro carbon)
22b rep vents (hydro carbon)
Retrofitted projectors w/ HIDs
ebay amber corners
JDM v6 grille w/ cherry blossom red badge
p1 rep front lip
Fiat flares
JDM rear bumper with spats
Carbon trunk w/ carbon prodrive rep spoiler
Wheels/Tires:
Rays Gramlights 57dr in bronze – 5x114.3, 17x9 +22
245/40 17 Bridgestone Potenza RE71r’s
______________________________ ______________________________ _
So, I owned a 2000 RS coupe named Betty the Boobaru (Betty the BOOBaru, 2000 RBP RSTi coupe) I had an awesome time building her... But I decided it was time to search for a house and chose to sell the car for extra money. I knew I couldn't go without an RS, so I was searching for a cheap, not so rusty car to start with. Oh, and I wanted a SEDAN this time
I found this 2000 aspen white sedan FS on here and on eBay. I threw in some bids and ended up winning the car for $2,550. I went and picked her up in MD in April 2015...and then sold Betty in June.
The car was mostly stock when I picked it up, but it did have a coupe spoiler and JDM taillights! oh...and had blue front calipers, drilled rotors....and it was automatic
The first thing to go was the auto trans. I picked up a rusted out, motorless parts car for 800 bucks. Parted everything else out and boom, free 5spd swap
Once I had a proper transmission, I started adding things here and there...
- JDM 22b vents
- MRT highrise hood scoop
- amber corners
- JDM rainbow foglights
- euro WRX front and rear seats
- extended armrest with CF cover (from Zealous)
- custom visors, black with pink stitching from JPM coachworks
...and some other stuff that I will have to remember and add to this...
Added ISC n1 coils and threw my volks on
Repainted the front calipers black, and dipped the wheels teal!
AND! Things to do before snow
- winter tires (on stock 6 spokes)
- JDM STi v6 suspension
- ball joints
- starter
- brakes (picked up new-to-me calipers with pads and rotors, and new stainless lines and adapters. bought rebuild kits for the calipers and will be repainting them.)
- gaskets/plugs/oil change on the motor
I have been super busy with work and just driving the car, adding things here and there. More posts and pictures to come!
Boobaru2: Betty White? So much for not being OCD again...-68471473_489072908318314_6328841177755811840_n.jpg
SPEND ALL THE MONEY
Last edited by BettyblueRS; Today at 09:04 AM.. Reason: *titanic meme*: It's been 84 years...
BettyblueRS is offline   Reply With Quote
Old 11-19-2015, 05:15 PM   #2
BettyblueRS
I ❤ BOOBIES
Fav Mod: por15
Trader Rating: (25)
What started as a clean-ish RS sedan turned into the "ratchet-ru"...
Fast forward to the summer of 2016, after telling myself over and over that I wasn't going to STi swap this car and spend a lot of money on it...
I found an STi swapped L coupe FS near me, and for a good price.
Thestory’s STi Swapped L
I bought it, swapped the goods into the sedan, and parted and scrapped the rest.
I drove the car like that for a bit with small changes here and there like an oem v5 spoiler, a roof rack, powdercoated the volks teal, and a carbon hood.
Then about a year ago, I had the car cut up and the fiat flares installed. Started with ESR wheels and then went to the 3pc SSR MS1's
A few pictures of the different looks she has had up to this point:
SPEND ALL THE MONEY
Old 11-19-2015, 05:15 PM   #3
BettyblueRS
I ❤ BOOBIES
Fav Mod: por15
Trader Rating: (25)
I'll use this post to update more about the most recent swap that started in April 2019.
Another coupe donor - 1999 White Impreza 2.5RS (update: found a short build journal on here for her - Bryan's AW '99 RSTi (Damn I love this car!))
2005 STi swap with only ~40k miles
From the FS listing:
Engine:
* 2005 EJ257, wiring harness, ECU, etc.
* FP HTA 71 Turbo w/
* 84mm compressor port
* Ported turbine housing
* Coated turbine housing
* Turbo blanket
* Tial 44mm External wastegate
* Cobb BCS
* Big custom top mount IC
* FP 84mm turbo inlet and custom intake
* Cobb Accessport V3
* Cobb downpipe (no cat)
* Downpipe-back 3” Aluminum exhaust
* TGV Deletes
* Koyo Radiator
* Killer B Oil Pickup
* DW850cc injectors
* DW300lph fuel pump
Driveline:
* 2005 STi 6 Speed Transmission
* Cobb Short Shifter
* ACT Clutch
* OEM Flywheel
* STi driveshaft, rear diff, axles, master cylinder, slave cylinder, front subframe, rear subframe, hubs, knuckles, short ratio steering rack, sway bars, endlinks
Suspension, Brakes, Tires:
* RCE Tarmac 2 Coilovers
* Vorshlag Camber Plates
* STi Front and rear brembos (ABS Works)
* Hawk HP Plus pads
* DBA 4000 rotors
* 1 set of 17x8 gold BBS
* 1 set of 17x8 silver BBS
* 235 R888R Tires
Interior (it’s stripped):
* Corbeau Forza FIA (driver)
* Corbeau Fx1 Pro (passenger)
* Corbeau rails and double locking sliders
* Defi Boost gauge
* STi Drive by wire pedal
* OMP WRC Steering wheel
* NRG fen 3 hub and quick connect
* JDM Ver 5/6 Cluster and OEM cluster
Exterior:
* Shaved Molding
* Carbon hood and big scoop
* Carbon trunk and JDM wing
* Fog light covers
* Retro fitted projectors and HIDs
The coupe was taken up to my buddy's garage (he's using the coupe shell for a JDM v6 wrx swap, I got to do all of this bs in an actual garage vs my driveway...everybody wins) and I stripped off everything I needed:
lolwut
The donor harness was merged by the previous owner and stripped for weight/autox, I wanted it back to oem spec. So I was able to use the donor harness and my old RS 5spd harness (from the silver sedan 5spd donor) to take to Zephyr and have a new merged harness created. Also had the DCCDPro installed at this time.
My sedan was stripped down and all the old stuff sold off:
The swap was done in my friend's garage but we had limited space, which turned into me bringing most of the exterior and spare parts back to my house for storage / to keep it out of our way.
My poor fiance, I stole our entire basement.
The goal for this new swap is still to be driveable on any given day, +weekend warrior, and actually giving track or maybe autox a try this time around.
SPEND ALL THE MONEY
Old 11-19-2015, 06:06 PM   #4
Bansheeboy11
I ❤ BOOBIES
Fav Mod: 300K Club
Trader Rating: (59)
Yo.
Bansheeboy11 is offline   Reply With Quote
Old 11-19-2015, 06:15 PM   #5
Bast
Fav Mod: Prodrive all things
Trader Rating: (4)
Yay!
Wolves don't lose sleep over the opinions of sheep.
Bast is offline   Reply With Quote
Old 11-19-2015, 06:32 PM   #6
BettyblueRS
I ❤ BOOBIES
Fav Mod: por15
Trader Rating: (25)
Originally Posted by Bansheeboy11 View Post
Yo.
Originally Posted by Bast View Post
Yay!
SPEND ALL THE MONEY
Old 11-19-2015, 07:10 PM   #7
jrouillard
Trader Rating: (22)
Nice!
'12 Dodge Ram - '00 L Coupe
jrouillard is offline   Reply With Quote
Old 11-19-2015, 09:50 PM   #8
skyline4me
Fav Mod: Evo 8 Recaros
Trader Rating: (37)
The Volks made it on the car! YES!
skyline4me is offline   Reply With Quote
Old 11-20-2015, 04:43 AM   #9
Ted
2.5L RS-T
Trader Rating: (3)
Looking good. A swap in the works for this one too?
A three syllable word for thoughts too big for small minds
Ted is offline   Reply With Quote
Old 11-20-2015, 06:41 AM   #10
Shaw
Shaw's Avatar
Car: 2010 Forester
Fav Mod: Your Mother
Better be as good as Betty
Pewp......
Shaw is offline   Reply With Quote
