Aczwild's '98 Impreza RS - AKA how to blow a lot of $$ to build a track slut - Subaru Impreza GC8 & RS Forum & Community: RS25.com
Old 06-26-2011, 11:02 AM   #1
Aczwild
2.5L
Fav Mod: RS-Zero's
Trader Rating: (9)
Default Aczwild's '98 Impreza RS - AKA how to blow a lot of $$ to build a track slut
So I guess its time to finally break ground on a new thread/ build journal for the car. I have always wanted to build a prepped car for Autox & track days (SLMP, LRP, MTS...) and I finally found what I was looking for.
I picked up a '98 Impreza RS 'Unicorn' just over a year ago from a member of Nasioc who was moving to Texas from Mass. He was the second owner since 2001 and he "babied' the hell out of the car (albeit a few winter TSD's and ice races). He handed over every single record he had (all alignments, work, etc) and a ton of parts. The car was never modded too much (ACT HD clutch and plate, Group N motor mounts, KYB front struts, Goodrige SS lines and a few other small things) and the car is pretty much rust free compared to a normal VT car (just started the normal rear quarter rust bubbles).
So immediately I started to mod the car to get it ready for Auto-x at the least for the 2011 season. Unfortunately some things have cropped up when working on the car and I haven't been able to get it out to the track, though I still drive it now and then on the street. I want to hold on to this car for a long time so I've been replacing anything and everything that isnt in almost new condition (yes all the way down to bolts, washers and nuts).
So here's the mod list to date (including items that have been ordered and items that are sitting in storage waiting to be put on when the rest of the accompanying parts come in) along with a few pics of the car. As you'll see in the mod list I'll be swapping the engine for a Turbo variant, I just have to decide which especially since I have a full long bolck EJ22T sitting in storage.
Modifications:
Engine
'03 WRX 2.0L Engine (personally rebuilt)
Gates Racing Timing Belt
Gates Racing Alternator/Power Steering Belt
GrimmSpeed Lightweight Crank Pulley (Black)
Cosworth Billet Timing Belt Guide
STI 11mm Oil Pump
STI Engine Mounting Plates
Cusco Engine Mounts
Brian Crower Adjustable Timing Gears
Black Perrin 2.4" Turbo Inlet
GrimmSpeed Header Gaskets
GrimmSpeed Throttle Body Gasket
JDM V9 VF37 Twinscroll Turbo
JDM V9 OEM Twinscroll Headers
JDM V9 OEM Twinscroll Up Pipe
JDM V9 OEM Twinscroll Downpipe
JDM V9 OEM Twinscroll Oil Pan
JDM V9 OEM Twinscroll Oil Baffle
JDM V9 OEM Twinscroll Oil Pickup
JDM Blitz 80mm Nur-Spec RX Catback
42 Autosports custom JDM Downpipe to Catback exhaust pipe
ARC Titanium Pulley Cover
Greddy Magnetic Drain Plug
GrimmSpeed Red Aluminum Oil Cap
Forced Performance non-AVCS Oil Supply line
OEM Thermostat
DeatschWerks DW200 Fuel pump & install kit
DeatschWerks Bosch EV14 1000cc Injectors
GrimmSpeed Manual Boost Controller
Beatrush Alternator Pulley
GR STi Passenger Side Hard Coolant Line
JDM STi TGV Top-feed Deletes
PTP Turbo Blankets Turbo Blanket Lava
GrimmSpeed Intake Manifold to TGV Gaskets
Denso Iridium Power Plugs One Step Colder
GrimmSpeed Top Mount Intercooler
GrimmSpeed TGV to Engine Gaskets - 2 sets
GrimmSpeed Phenolic Thermal Spacer 3mm
GrimmSpeed TMIC Y-Pipe Kit Black Couplers
GrimmSpeed Intercooler Y-Pipe Gaskets
GFB 50/50 Hybrid BOV
Moroso Aluminum Coolant Expansion Tank
DEI 12"x12" Reflect-a-Gold Sheet Behind Downpipe
Boxer4Racing Remote Oil Pressure sender kit
SPT Intake
OEM Air Conditioning Delete Bracket
Air Conditioning system fully deleted
Koyo Racing aluminum radiator 36mm Hyper V core
'02-'07 WRX GrimmSpeed Radiator Shroud - Modified to work with '98 RS
Cobb Accessport V3-Sub 001
Transmission
JDM V8 STi S203 6-Speed Transmission w/ DCCD
MAP DCCD Differential controller
JDM SG9 Forester STi Suretrac R180 Rear Diff
Auto-tragic Driveshaft
JDM GC8 STi RA R180 Rear Axles
Cusco Transmission Mount
Kartboy Pitch Stop
Exedy Clutch
Exedy Pressure Plate
Goodridge Stainless Steel Clutch line
Clutch Delay Valve deleted
TIC Shift Linkage Bushings
TIC Pivot Bushings
Kartboy Front Shifter Bushings
Kartboy Rear Shifter Bushing
Kartboy Transmission Cross member bushings
OEM STi Short Throw Shifter Assembly
07 Spec B 6-Speed Shift Knob (from the first Subaru I ever purchased new)
WC Lathewerks STi Brushed Titanium Shift Knob
OEM GC Altimeter/Compass Pod & DIN Bracket
White HVAC LED Conversion
White LED Gauge Cluster Conversion
White LED Window Switch Conversion
LED Map Lights
LED Dome Light Array
Trunk Light Added & converted to LED
Remote Unlock Added
Passenger side Oh-**** Handle Added
Beatrush Aluminum Rear Seat Delete Panel
Brey Krause Fire Extinguisher Mount
Amerex 2.5lb fire extinguisher
Nardi Deep Corn 350mm Steering Wheel w/ Baller Bolts burnt Ti hardware
Works Bell Short Hub
Works Bell "Yoshioka" Quick Release
RIPT Interiors Black Carpet
1/2 Gutted Interior - Per SCCA SM Class rules
Gutted Trunk
Drivers side & Passenger side Airbag delete
Sparco EVOII GrpTech Seats
Sparco Bases
Sparco Side Brackets
Takata 4pt Harnesses
Takata 6pt Harness Straps
Schroth 3" 3 Bar slides (4x) - Need these to properly mount the Harnesses
Kales Custom, Custom 4pt Cage
52mm Stack Mechanical Oil Pressure gauge
52mm Stack Mechanical Boost Pressure gauge
52mm Stack Wideband gauge
'99-01 RS Front Bumper
'99-01 RS Clear Bumper turn signals
'99-01 RS Crystal Headlights
Prodrive P1 Fog Light Kit
LED Plate Lights
JDM "Clear" Tail Lights (Brand new)
JDM Clear Parking Lights (Brand new)
Grimmspeed Antenna Delete
L'aunsport Gr.A WRC Carbon Fiber Aero Mirrors
JDM STi V6 Grille
JDM WRB I Badge
Clear Front Bumper Turn Signals
Clear Sidemarker Turn Signals
Australian Head Light Protectors (Clear)
Bakemono CF S201 scoop
Suspension/Handling/Braking
JDM V4 WRX Front Subframe
GC8 Aluminum Control Arms
Whiteline Tie-rods
Group N Top Hats
KYB AGX Struts (front only)
Goodridge Stainless Steel Brake lines (Front)
Stoptech Front 4 piston Calipers (Black)
Stoptech 2-piece Floating 328x28mm Slotted AeroRotor (Front)
Stoptech Stainless Brake Lines (Rear)
Axxis Ultimate Front Brake Pads
Brembo RBF 600 Brake Fluid
STi Brake Master Cylinder
GrimmSpeed Master Cylinder Brace
JDM GC8 STi RA Rear Subframe
JDM GC8 STi RA Rear lateral links
JDM GC8 STi RA R180 Rear Hubs
STI Pink Rear trailing arms w/ spherical bushings
Whiteline BSR20XXZ 24mm rear sway bar
Whiteline KLC26 rear sway bar end links
Whiteline KBR21-24 24mm rear sway bar mounts
Whiteline KLL124 24mm rear sway bar lateral locks
2004 STi Brembo Rear Calipers - Powder Coated Semi Gloss Black & 100% Rebuilt w/ Brand new OE components
DBA 4000 Rear Brembo Slotted Rotors for retrofit onto early Imprezas
StopTech Street Performance Brake Pad - 2004 Subaru Impreza WRX Sti - Rear
7 good 17x7.5 +48 STi Rays RS Zero's (Ultra friggin rare) - 1 w/ borked lug holes
STi Rays RS-Zero Center Caps - Refinished
225/45/17 Dunlop Direzza StarSpec Z1's
Eibach 5mm Wheel Spacers (Subaru hub specific)
Driver
Loose cannon
Aczwild's '98 Impreza RS - AKA how to blow a lot of $$ to build a track slut-dsc03426-1.jpg
Aczwild is offline   Reply With Quote
Old 06-26-2011, 11:05 AM   #2
Snakebite420
Fav Mod: EJ257 & GTX30R
Trader Rating: (16)
oooh very nice =D
You make-a mah teeth hurt so bad! - Dr. Tran https://www.youtube.com/watch?v=FO0kRE5OTZI
Snakebite420 is offline   Reply With Quote
Old 06-26-2011, 12:07 PM   #3
Aczwild
2.5L
Fav Mod: RS-Zero's
Trader Rating: (9)
Little background on me too, the last modded car I had (still have it, its just pretty much back to stock and is my DD/Professional car) is my '07 Spec B.
It was modded as follows
Engine & Exhaust:
  • JDM Engine Covers
  • GReddy EVOII Cat-back Exhaust
  • AVO Panel Filter
  • GTSpec Aluminum Under Panel
  • GFB 50-50 BOV
Exterior:
  • Cleared USDM Headlights
  • Rally Armor Mud Flaps (Thanks MSPT!)
  • Mach V LED Plate lights
  • Hella Supertones Horns
  • Hella High Performance Xenon Headlights
  • Hella High Performance Xenon Fogs
  • Subimods Hella Supertone Wiring Harness
  • 20% Tint all the way around (except the front windshield)
  • Totsubo JDM to USDM License Plate Brackets
  • JDM Spec B Badging
  • JDM Stanza Carbon Fiber Eyelines
  • JDM Spec B Front Bumper
  • JDM STi Rev D Honeycomb Grille
  • JDM STi Spec B Lip Spoiler
  • JDM Rear Bumper (Dual Exhaust)
  • JDM ScLaBo Rear Spats (JDM only Biatches!)
Interior:
  • Mach V LED Door, Dome, Map and Trunk Lights (friggin sexy)
  • Kartboy Short Throw Shifter
  • Defi BF White Boost Gauge
  • Defi 60mm A-pillar Pod Mount
  • Defi 60mm Visor
  • "CF" wrapped trim
Suspension/Brakes/Handling:
  • Cusco Carbon Fiber Front Strut Tower Brace
  • Racecomp Engineering Tarmac 1 Coilovers w/ Spec B tophats
  • Cusco Front Under Bracing
  • Cusco Rear Under Bracing
  • Kartboy Front Endlinks
  • Whiteline 22mm Front Adjustable Swaybar
  • Whiteline 22mm Bushings
  • Kartboy Rear Endlinks
  • Whiteline 20mm Rear Adjustable Swaybar
  • Whiteline 20mm Bushings
  • AVO Rear Swaybar Reinforcement Brackets
  • Stoptech Front 4piston Calipers (Black)
  • Stoptech 2-piece Floating 328x28mm Slotted AeroRotor (Front)
  • Stoptech Front Stainless Brake Lines
  • Stoptech Rear Stainless Brake Lines
  • Axxis Ultimate Front Brake Pads
  • Motul RBF 600 Brake Fluid
Wheels and Tires:
  • 17x7" Bronze MB Weapon's w/ 215/50/R17 Michelin X-Ice Xi2's
  • 225/50/R17 Hankook Icebear W300's (Backup Winter Setup)
  • 18x7" Stock Spec B. Rims w/ 215/40/R18 Potenza RE090A's
  • 18 x8.5" +45 Linea Course Lemans w/ 235/40/18 Dunlop Direzza Sport Z1 Star Specs
Racks & Accessories:
  • Thule Roof Rack
  • Thule Kayak Racks
  • Thule Paddle Carriers
  • Thule 611 Boxter
Whole lotta time and $$ into that car before I parted it out to make way for the RS.
Old 06-26-2011, 12:18 PM   #4
Mikey B
Mikey B's Avatar
Fav Mod: Driver Mod
Trader Rating: (19)
thats a bad ass LGT
Im gonna put a breathalyzer on the the " new topic" button.
Mikey B is offline   Reply With Quote
Old 06-28-2011, 04:27 AM   #5
Aczwild
2.5L
Fav Mod: RS-Zero's
Trader Rating: (9)
Thanks,
Just finished rebuilding the rear Brembos. Just waiting for the DBA kit to come in from Mach V and the spacers from Subimods
Old 07-14-2011, 07:29 PM   #6
Aczwild
2.5L
Fav Mod: RS-Zero's
Trader Rating: (9)
Brake system upgrade under way on the RS...
Shiat to do over the next few days:
Hook up the Rear SS brake lines to the Brembos
Drain stock RS Master Cylinder
Remove stock MC
Replace stock MC with STi MC
Remove StopTech BBK from LGT
Put stock brakes, calipers and rotors back on LGT
Bleed LGT system
Remove stock RS front Calipers, pads and rotors
Install StopTech BBK
Hook up front SS brake lines
Bleed RS system
Install 5mm H&R spacers
Put RS-Zeros back on
Adjust parking brake pads
Old 07-14-2011, 08:15 PM   #7
Pudge
Fav Mod: NEthing to keep it runnin
Trader Rating: (9)
dude love the rims. maybe we can cruise sometime
need a swap now
Pudge is offline   Reply With Quote
Old 07-16-2011, 06:39 PM   #8
Aczwild
2.5L
Fav Mod: RS-Zero's
Trader Rating: (9)
Hook up the Rear SS brake lines to the Brembos - Done
Drain stock RS Master Cylinder - Done
Remove stock MC - Done
Replace stock MC with STi MC - Done
Remove StopTech BBK from LGT - Done
Put stock brakes, calipers and rotors back on LGT - Done
Bleed LGT system - Done
Remove stock RS front Calipers, pads and rotors - Done
Install StopTech BBK - Done
Hook up front SS brake lines - Done
Bleed RS system
Almost done, just have to Bleed the system and adjust the parking brakes tomorrow!
This thing is going to be so damn nasty! Gotta get used to the stock brake pedal feel in the Spec though
Oh and all I have to say is I love the Motive Power Bleeder System and catch bottles!
Old 07-16-2011, 06:43 PM   #9
Aczwild
2.5L
Fav Mod: RS-Zero's
Trader Rating: (9)
Thanks man, I love these too, so much so that when I found out the hard way the the original owner from Hong Kong hadn't disclosed one of the lug patterns on a wheel was totally fucked, I tracked down a second set here stateside and was able to score them to fix the issue. Course that meant that to have this look with the wheels I spent a little over 3K! But at least I have replacements for one of the rarest and hardest to come by sets of Subaru aftermarket wheels.
I'll let you know when I'm down your way. I love to just go on random drives and as this car progresses I'll love them more and more. Cant wait to test out these brakes!
Old 07-16-2011, 07:00 PM   #10
ThatGuy
Fav Mod: Six Cylinders
Trader Rating: (5)
Yeah, I'm in Japan and have seen your wheels maybe 5 times. And I saw a 22B yesterday. Let's just say I keep a lookout for older Imprezas and Gold 5 stars, especially if they are forged monoblock. Much jealous, take care of them!
ThatGuy is offline   Reply With Quote
