Subaru Impreza GC8 & RS Forum & Community: RS25.com - View Single Post - Bast's MY99 RS - Prodrive P1 Replica
Old 09-19-2013, 10:20 PM
Bast
Fav Mod: Prodrive all things
Trader Rating: (4)
Here's what the dealer replaced prior to my purchase (all repairs done at ~124,000 miles):
  • New OEM Subaru head gaskets
  • New OEM intake manifold gaskets
  • New OEM Subaru cam seals
  • New OEM thermostat
  • New OEM thermostat gasket
  • New OEM oil pump o-ring
  • New valve cover gaskets
  • New spark plug tube seals
  • New washer rocker grommets
  • New drive belts
  • New timing belt (OE Gates brand)
  • New spark plugs (NGK)
  • New oil and filter
  • New anitfreeze
  • New ACL rod bearings
  • New ACL main bearings
  • New piston ring set
  • Transmission flush with Redline
When I took it for a test drive, the driver's side amber corner light flew off. They replaced those with the depo black corners (yuck!). It had fading pin stripes, slight rust, a busted driver's side mirror and awful deflectors on the hood and moonroof. That said, it was a diamond in the rough and I had to have it.
Last edited by Bast; 07-24-2019 at 11:57 AM.. Reason: Updated with engine rebuild parts from dealer
Bast is offline   Reply With Quote
