Dan7140's "T-Minus" Track Car Build - Page 15 - Subaru Impreza GC8 & RS Forum & Community: RS25.com
Old 09-19-2018, 05:16 AM   #141
Dan7140
Impreza Actual
Fav Mod: 13 Subarus deep...
Thanks guys. So I was very excited at my road course times considering I only normally auto-x, but after seeing the posted lap times of the more experienced drivers I am shocked.
I looked around and found some youtube runs and am blown away with how much faster these guys can corner. What am I doing wrong? I was following their lines, but just don't have the grip. Is it alignment? Tires? Tire pressure?
I thought new RE71Rs were good enough, I ran 26 psi front which heated up to about 29 psi by the end of each session. Maybe my lack of aero and horrible weight balance, but some of these fast cars were STOCK.
Obviously I have plenty to learn and more seat time is always needed, but man. These two badass SCCA Miatas were killing almost everybody and although they were loud, they had no power... So I know my power level isn't the issue, it's definitely the corners. Am I just handicapped with my suspension geometry? Are my coilovers too stiff? Stock WRX rollbars too small? HELP!
I kill threads.
Dan7140 is offline   Reply With Quote
Old 09-19-2018, 05:28 AM   #142
TerryJr
Experimenter
TerryJr's Avatar
Fav Mod: AAA Premier
car looks good
Why should we be paying to keep guy's like Chris Watts and Michael Glance alive?
TerryJr is offline   Reply With Quote
Old 09-19-2018, 01:30 PM   #143
bue car
#32
bue car's Avatar
Fav Mod: Which car?
Trader Rating: (174)
More seat time as you said. Learning how to throw your weight around, aggressive alignment (a good base is -3/-2.5 camber), learn the car and your boundaries, and honestly, that could mean fish tailing it a bit and learning to correct it. One beginner issue as well is as soon as the back end slips, they let off the gas. This will make you snap in the other direction causing you to loose control. She starts going, you let up a tiny bit until she bites again, then you can slow your roll a bit more and catch your nerves haha.
Save RS25! Say no to XenForo
bue car is offline   Reply With Quote
Old 10-31-2018, 06:48 AM   #144
Dan7140
Impreza Actual
I uploaded a quick update for my friends but I'll throw it here too.
I plan on removing the rear section of my exhaust for a few reasons.
1 - The car is way too quiet at the road course
2 - Weight reduction Bro.
3 - I plan on making a rear diffuser out of carbon fiber. The exhaust is in the way. I have this whole aero plan but who knows how long it will take to achieve as I have limited time and funds ever since I bought my new house.
That being said, I worry about the exhaust gas interference/additional air flow ruining that idea so I might have to have an ovaled side exit or MAYBE have the piping run through the car and out the side or even rear of the car, that'd be neat!
Since it currently has a custom rotated turbo downpipe that is longer than normal, technically I just stopped it at the end of the downpipe a little after the wwideband o2. Not sure if this will be too loud at WOT or if it will affect the o2 reading. My guess is no/IDGAF.
Also, the rear subframe is dropped so I can drop the fuel tank as it leaks real bad - most likely from my halfass evap delete or maybe a cut return line or something. I also plan on doing the outrigger bushings? - The ones that are at the end of the T bar for the diff.
I kill threads.
Old 11-02-2018, 03:24 AM   #145
bue car
#32
bue car's Avatar
Fav Mod: Which car?
Neat? No, running the exhaust inside is one of the stupidest things to do.
Side exit now? fuck yea.
Just sell the house and copy said build:
GC8 Track Aero - Double Deck Rear Diffuser - ScoobyNet.com - Subaru Enthusiast Forum
PS - Check out his exhaust tip...
Old 11-02-2018, 06:47 AM   #146
Dan7140
Impreza Actual
That's one of the builds that gave me some ideas lol. Insane.
I kill threads.
Old 09-12-2019, 10:35 AM   #147
Dan7140
Impreza Actual
I have a severly lightened (I have a lot to update on my thread ) and stiffer car than stock and have a DSS 1 pc carbon driveshaft. The vibration at 75+ is horrific. I've rotated 90 degrees over and over. Thoughts?
I should add that the differential t-brace weights were stripped off - do those soak up that vibration?
I kill threads.
Old 09-12-2019, 11:59 AM   #148
SoCoNoHa
2.7L
Fav Mod: Anything custom
I wouldn't think there should be much vibration to dampen. I would find a driveshaft shop or someone who can balance it.
97 LGT / 92 SVX / 95 GM∆
SoCoNoHa is online now   Reply With Quote
Old 09-13-2019, 12:22 AM   #149
bue car
#32
bue car's Avatar
Fav Mod: Which car?
Ouch. I always her either really good or really bad on these 1pc shafts. IDK what I want myself
