Hi guys! I am back with another Subie. My old thread can be found here. The goal of this new car is to get it ready for Auto-X over the winter and then build it over time for the road course as well.
A very good friend of mine whose username on here is Snowbum has owned it for probably the last ten years or more. It is a 2001 2.5RS with 117000 miles. It is painted Porsche Seal Grey 6B5.
The rust on the outside and the dings and scratches here and there aren't the greatest, but inside the car and underneath it is in very good condition.
I need to start recording my weight and what I have done to get there:
Currently weighs 2260 lbs with a full tank of gas - 1420 front and 840 rear. (even lighter now, will weigh later)
Carbon fiber: roof, hood, doors, side windows, and trunk lid - All on Quik Latches except roof
Antigravity 3 lb battery
DSS Carbon Fiber Driveshaft
Sparco single seat - Sparco aluminum seat rails
Flat aluminum panel trunk with spare tire tub cut out (wasn't even heavy )
SSR type Cs
ABS delete
Power Steering delete and gutted rack internals and welded lines shut. Wheel bearing grease used.
No sound deadening but has full interior put back in.
No A/C - completely deleted everywhere even in heater core area
No airbags, NRG steering wheel
lightweight crank pulley
ACT lightweight flywheel
Gutted sound deadening from firewall to trunk, interior is pretty much mocked up but bolted down.
Sunroof motor assembly removed and sunroof is bolted in place.
Aluminum GD front control arms
Intake manifold and heads are ported/gasket matched
Reversed intake manifold for less FMIC piping
No IACV and very trimmed/ported throttle body.
Side impact bar delete :run:
Both bumper beams are pretty much non existent
ISC Coilovers
No radio
No speakers
No fogs
Current upgrades: (Installed as of now)
Engine
Hydra Nemesis v2.5 - Tuned by RS Motors 15 PSI
EJ22E shortblock ~90-100k miles on it (welded 10AN turbo oil return in pan)
EJ257 crank/rods/ARP rod bolts/oil pan
2.5RS SOHC ported heads
Supertech Dual Titanium Valvesprings
Delta Cams (2000 on intake and 1000 on exhaust) .006 in .008 ex
ARP Head studs
Garrett G25-550 Turbo - AN coolant/oil lines
Reversed manifold
Injector Dynamics 1050X injectors
Aeromotive WRX fuel rails
Aeromotive RRFPR
Parallel fuel lines with AN fittings
Walbro 255lph pump
Killer B Holy Header low mount (321 Stainless)
Tial 38mm EWG
(Spot reserved for EBC)
NGK BKR7EIX-11 (1-step colder plugs, can't remember what I gapped them too, should be around .028-,032)
10mm oil pump
05-20 EJ257 Oil Pan with 10AN return bung welded on
CXRacing FMIC
Trust/Greddy Front Mount Oil Cooler with Earl AN-10 lines and Earls swivel fittings
Mishimoto aluminum rad/shroud/ electric fans - aluminum sheet riveted in to fill in side air gaps
Silicone hoses
Forge BOV FMDVSUB03
Grimmspeed AOS
Lightweight Crank pulley - not dampened
Turbosmart Manual Boost Controller
JDM coolant in-fender overflow tank
Antigravity THREE POUND Battery AG-1201 12 Cell
DEI 2" x 35ft Titanium Exhaust Wrap
PTP Turbo Blanket Heat Shield - Lava
Drivetrain
Version 6 STi RA V-Limited 5spd DCCD Helical front diff (TY754VB1EA) Up to 47% wider teeth and steel shift forks instead of aluminum
Group N transmission mount
Whiteline Transmission Crossmember Bushing
Whiteline Diff Support Outrigger Bushings (destroyed these trying to press in, went with Powerflex PFR69-118 Instead)
Whiteline Rear Trailing Arm Front Bushing Kit
Whiteline Rear Trailing Arm Lower Rear Bushing
Laile Beatrush rear diff brace
Laile Beatrush forged pitch stop mount
Cusco hyper gum shift linkage bush
DSS Carbon Fiber Driveshaft SUSH1-C
R160 SureTrac rear diff
05 Forester XT rear axles (were the same length - so confused)
ACT SB9-HDSS Clutch
Kartboy Short shifter
ARP Extended wheel studs (did all 4 OEM wheel bearings as well)
MUTEKI SR45R Burned Titanium 45mm M12x1.5 open end lug nuts
Suspension
ISC N1 coilovers 10K Front 8K Rear Track valving with thrust bearings
GD STI front lower control arms
M4iF Fender Braces/Cowl Stays
Whiteline Rear Lateral Links for GD STI width
Whiteline Anti-lift Kit
Whiteline Front Lower Control Arm Bushing
Whiteline Steering Rack Bushings 25MM
Whiteline Tie Rod Ends - Roll Center Adjustment
Whiteline Lower Ball Joints - Roll Center Adjustment
Whiteline Subframe Locking Bolts
Mines H-Brace
20mm front swaybar 05 WRX
Turbo front subframe
WRX year? 17mm rear swaybar with Audi solid front endlinks in the rear
Wheels/Tires/Brakes
SSR Type C 17x8.5 +48
Bridgestone Potenza RE-71R 255/40/17
Cadillac CTS-V Brake calipers and adapters
DBA 4000 rotors
Hawk HPS pads F
Hawk HP+ pads R
ATE type 200 fluid
SS Brake lines
Brake master cylinder brace
Ebay flares riv-nutted on(2 sets of fronts all the way around)
STi Fog covers
V6 style front lip
Rally Armor mudflaps
JDM Rear bumper
JDM tails
JDM rear spats
APR Carbon Fiber race mirrors
Carbon Fiber Hood ~several lbs
Carbon Fiber Roof ~several lbs
Carbon Fiber doors that detach with Quik Latch ~4 lb total door weight
Carbon Fiber Trunklid that detaches with Quik Latch ~several pounds
Carbon Fiber rear side window deletes
6 pt cage that is also welded in numerous places. DOM 1.5"x.095" and .120" wall 1020 steel
Some gauges Boost/Oil Pressure/Oil temp/Water temp/AFR/Fuel Pressure - will be tidying/refreshing that)
Sparco seat with Sparco aluminum seat rails
CROW 5 pt harness with quick release cam
Fire extinguisher
Fluids
Rotella T6 in engine
Regular 50/50 in cooling system
Extra S in transmission
Redline 75/90 and a little bit of Extra S in the rear diff
For me:
I didn't take too many pics before tearing into things I wanted to get done.
Mr. Earl loves this car so much for some reason!
SSR type Cs
ABS delete
ISC Coilovers
No radio
No speakers
No fogs
Engine
ARP Head studs
Reversed manifold
Aeromotive RRFPR
Walbro 255lph pump
Tial 38mm EWG
10mm oil pump
CXRacing FMIC
Silicone hoses
Forge BOV FMDVSUB03
Grimmspeed AOS
Drivetrain
ACT SB9-HDSS Clutch
Suspension
Mines H-Brace
Wheels/Tires/Brakes
DBA 4000 rotors
Hawk HPS pads F
Hawk HP+ pads R
ATE type 200 fluid
SS Brake lines
STi Fog covers
V6 style front lip
JDM Rear bumper
JDM tails
JDM rear spats
Fire extinguisher
Fluids
For me:
