Mike's 95 STI Type RA -> 95 L Coupe! We're going hybrid CDB. - Page 13 - Subaru Impreza GC8 & RS Forum & Community: RS25.com
Old 07-18-2017, 01:28 AM   #121
Michaeld
Fav Mod: Tires
IAG Stage 2.5 Closed deck has been ordered. Plan is to use the 2L heads and all the stuff I had purchased for them. Machine them to match and then go from there for the hybrid build. Uncharted waters for me, but I've been doing lots of reading. Making the most of what I have. I think it'll be fun.
Michaeld is offline   Reply With Quote
Old 09-22-2017, 03:16 PM   #122
Michaeld
Fav Mod: Tires
Back from deployment, closed deck block is here. Heads are being sent off to Outfront for bowl machining for the chamber match. Sorting out an oil cooler situation is my current project on my plate. Then once the heads are back and the motor built back up, itíll be time to focus on this darn NA intake manifold. Fueling stuff, wiring, the list goes on.
And one from the memory bank for funsies.
Old 09-23-2017, 07:13 AM   #123
Michaeld
Fav Mod: Tires
I was rifling in my attic for some uniform stuff and figured Iíd set this on the wingless trunk to see what it actually looks like. Neat.
Old 09-23-2017, 08:41 AM   #124
bue car
#32
bue car's Avatar
Fav Mod: Which car?
Trader Rating: (173)
mmm peaches
Group C Performance - Feel free to follow me, I'll start posting car stuffs - @cdrong32
bue car is offline   Reply With Quote
Old 11-20-2017, 04:28 PM   #125
Michaeld
Fav Mod: Tires
Engine starting to come together after waiting on little stuff. Holidays are expensive and the wife wants to go home to California so cash flow is tight making progress slower than ever.
Still collecting parts, but this is rejuvenating for a project that i thought was hitting a brick wall.
Old 11-20-2017, 05:57 PM   #126
bue car
#32
bue car's Avatar
Fav Mod: Which car?
Purdy.
Love it
Old 11-20-2017, 08:42 PM   #127
FryphaX
FryphaX's Avatar
Fav Mod: Registration!
Trader Rating: (4)
Well, I need a new pair of drawers.
Old 07-22-2018, 04:14 AM   #128
Michaeld
Fav Mod: Tires
Not a whole lot to update, i lost motivation there for quite a while. Got some stuff done this past week and i think Iíve got it back. The iWire harness is pretty much all thrown in and buttoned up. Iíll finish when i get the dash/cluster back in during the interior phase.
Both subframes are out and stripped. I learned during install of both that i need more parts to make it work. Swapping my GC LCAís for GD ones sooner than i thought to avoid issues with fitment on the bugeye front crossmember. So thatís on hold.
Got the rear subframe out finally. Broke a nutplate/welded nut taking the trailing arm off, but was able to cut the bolt and retrieve the nut in the frame. I may be able to finagle another nut on through the drain plug right there. We shall see. Fuel tank is also out, everything was pretty corroded and i wanted to run a fuel cell anyways swapping over to E85. The whole fuel system is getting swapped out, so the stock guy is trash.
Rear TSS subframe is installed and the R180 thrown into its new home. Probably will be back out again, but i was being zealous and wanted some progress. Also forgot i needed adjustable lateral links with the TSS frame because it does not allow for the camber adjustment bolt to be utilized. So now i gotta wait for that too. Lateral links and LCAís and it will be back on the ground as a rolling chassis.
Hopefully Iíll be posting more often again as my family is growing and Iíve got to get this guy done before my little babe pops out.
Old 07-22-2018, 02:22 PM   #129
bue car
#32
bue car's Avatar
Fav Mod: Which car?
Pull out the cash from under the bed as I say. Leave the frame, buy the links.
Old 09-07-2018, 07:25 AM   #130
Michaeld
Fav Mod: Tires
Picked a set of GD STI control arms and some adjustable lateral links a little while back. Nothing fancy, but theyíll get me on the ground. If they last a year, Iíll be happy.
Also got a real floor jack. My trolly jack has tried to kill me a few too many times.
This also finally showed up this AM. BNM Fab FogTurbo kit. Iíve been waiting an excessively long time for this to be built and arrive. It really is incredible craftsmanship though. Got a bumper exit blast pipe and EWG dump along with a down pipe setup to run a factory style exhaust. Like a mullet if you will. Anxious to get it installed, but i canít rush it. Plenty else to do.
Between work, going back to California for vacation, and an upper respiratory infection, not much is done. But my little girl is due in Feb, so the clock is definitely ticking.
