The Red Bomber and other orphans - Page 10 - Subaru Impreza GC8 & RS Forum & Community: RS25.com
Old 04-15-2015, 10:14 AM   #91
George.of.the.Jungle
Baby❤Daddy
George.of.the.Jungle's Avatar
Fav Mod: BOOOOOOST!!
Trader Rating: (75)
i'm sure it's different on different chassies..or how ever the hell you spell that. i've only ridden on them in an Abarth. over shiit roads..you have to hold your butthole closed or you'll poop all over the seats. on good roads..they ride like glass.
Old 04-15-2015, 05:43 PM   #92
jeffsnyder
jeffsnyder's Avatar
Fav Mod: Spray Foam
Trader Rating: (51)
Some plastic surgery with a face lift done today.
yep, that is the bumper beam, well skin holder
bumper installed:
on the ground:
then i tried installing my control arms and i found out that they didn't fit. i didn't know there are a wide and narrow for the front bushing and well i got the wide probably made for the gd
jeffsnyder is offline   Reply With Quote
Old 04-15-2015, 06:25 PM   #93
Mooseinabox
Car: 1998 OBS
Trader Rating: (10)
Any chance you have a picture of the wide vs narrow bushing you're referring too?
Mooseinabox is offline   Reply With Quote
Old 04-15-2015, 06:34 PM   #94
jeffsnyder
jeffsnyder's Avatar
Fav Mod: Spray Foam
Trader Rating: (51)
the only issue is length of the sleeve for the front position bushing, is 61mm.
some models use a bushing with a sleeve length of 55mm.
that is the issue i had, you will need to measure it out.
i got the prothane bushings and they had the wider ones, i need to order the whiteline bushings
Old 04-16-2015, 01:12 AM   #95
JdmGary
Authorized Vendor
Private Classifieds
JdmGary's Avatar
Car: 2.5RS
Fav Mod: Swaybars
Trader Rating: (446)
Bumper looks perfect on there. A+
JdmGary is offline   Reply With Quote
Old 04-16-2015, 06:09 AM   #96
Crash187
Fav Mod: What is a mod?
Trader Rating: (33)
If you want to resell the wide ones let me know I need those for my wrx subframe
Join The Meat Revolution http://www.facebook.com/groups/459984660739700/
Crash187 is offline   Reply With Quote
Old 04-16-2015, 06:19 AM   #97
jeffsnyder
jeffsnyder's Avatar
Fav Mod: Spray Foam
Trader Rating: (51)
they are the one piece bushings. not the two piece.
if i can get them out without destroying them (aka no getting annoyed), i'll let you know.
i still have the turbo inlet if interested
Old 04-16-2015, 06:20 AM   #98
Crash187
Trader Rating: (33)
Lol just let me know on everything once you figure it out, I'm guessing you actually got a GC8 crossmember? Or are you running a wrx one
Old 04-16-2015, 06:27 AM   #99
jeffsnyder
jeffsnyder's Avatar
Fav Mod: Spray Foam
Trader Rating: (51)
i got one from a turbo legacy
Old 05-13-2015, 07:20 AM   #100
jeffsnyder
jeffsnyder's Avatar
Fav Mod: Spray Foam
Trader Rating: (51)
catch up time, been way to busy with it being nice outside to play on the computer.
aluminum control arm install after i got the correct front bushing installed, with new ball joints and kartboy end links.
Also decided to install the subaru 4 pots and kick out those tiny single piston brake calipers.
a big woops on my part, don't forget to check to make sure your brake lines are not rubbing on anything or you can end up with this:
