Alter's RS project - Page 3 - Subaru Impreza GC8 & RS Forum & Community: RS25.com
Alter's RS project
Old 10-16-2013, 02:25 PM   #21
Good_Lord
2.0L
Now I'm definitely suscribing to your thread ! I'm going to take notes for my own RSTi project, which I'll try to start after school is done
Good_Lord is offline   Reply With Quote
Old 10-16-2013, 03:08 PM   #22
Reverend86
2.7L
Trader Rating: (3)
This looks like it'll be a great project. Better take my seat while I can and follow along!
Reverend86 is offline   Reply With Quote
Old 10-20-2013, 02:07 PM   #23
alter_
2.7L
Car: 1998, RS, Rally Blue 2.0 EJ20K
Fav Mod: JDM EJ20k swap
Rain didn't allow for much to be done on the car this weekend. Got the rear diff reinstalled however.
alter_ is offline   Reply With Quote
Old 10-23-2013, 07:41 PM   #24
alter_
2.7L
Ok so I had someone come over tonight ot help out with some wiring. Will take some updated pictures tomorrow. One big thing that we found was I don't have a vf39 on my engine. Turns out it has a vf22. Not sure how i read that incorrectly the first time through. Should be interesting if I can get this car together.
Ran into an issue. Power steering lines were cut on the ej20k. Not on the hardline but after that. Can I still use my stock lines?
Old 10-24-2013, 08:27 AM   #25
alter_
2.7L
made some more progress on wiring last night
Daylight is slipping away from me fast!
Old 10-24-2013, 12:31 PM   #26
alter_
2.7L
Got the crossmember out and the power steering out. Discovered a torn boot on the passenger side. I guess I should replace that as well?? I never noticed anything wrong with it but a torn boot is never good. I also busted 3 out of 4 bolts that hold it in place. Was going slow, using a torch and pb blaster but it still broke.
Ready for the new cross member
different angles
New cross member in
Old 10-29-2013, 01:31 PM   #27
alter_
2.7L
small update
Installed a 22mm adjustable rear sway bar. Broke a bolt on the left and will have to drill that out.
old vs new
Old 10-30-2013, 05:37 AM   #28
BettyblueRS
I ❤ BOOBIES
Fav Mod: por15
Trader Rating: (25)
awesome, I have the same bar and love it
SPEND ALL THE MONEY
BettyblueRS is offline   Reply With Quote
Old 10-30-2013, 05:50 AM   #29
trx450r1989
Car: 2000 rs2.5/96 brighton ej20
Great build tread so far! I am working on EJ20K too.
Aerodynamics are for people who canít build engines.
trx450r1989 is offline   Reply With Quote
Old 11-10-2013, 02:04 PM   #30
alter_
2.7L
quick update.. Finished the electrical wiring for the most part. Need to get the car started first then I will button everything up. (need access to ecu to prime engine, etc, etc)
Crossmember installed with power steering. Just need to connect the power steering lines.
From the bottom.
