GDB Impreza RS2.5 Supercharger system/s - Page 6 - Subaru Impreza GC8 & RS Forum & Community: RS25.com
Old 12-26-2008, 03:38 PM   #51
Shiffy
Fav Mod: Cams for sure
I'm glad to hear the boost CAN be raised. It gives us room for improvement.
Like when I blow this block I can build another one with lower compression pistons and jack up the boost.
So does a self contained unit require any maintenance. Lube changes and such?
Shiffy is offline   Reply With Quote
Old 12-26-2008, 06:09 PM   #52
ElvisC
2.7L
Originally Posted by Tradewind View Post
The Raptor V SC is self contained, no oil connections at all. No oil connections at all. Just bolt charger to bracket and apart from the obvious air connections to and from charger
Will it include the special oil needed to lube the inner gears?
ElvisC is offline   Reply With Quote
Old 12-26-2008, 06:13 PM   #53
ElvisC
2.7L
Is this the Piggyback for the kit?
http://www.moristech.com.au/pro-sequ...nterceptor.asp
If so that's pretty solid since it doesn't modify any sensor signals. But without spark control i wouldn't recommend going above 9psi. (assuming the spark advance is ~20-21 degrees @ WOT)
I apologize for the questions.
edit: i see it can change spark timing.
Old 12-27-2008, 02:20 AM   #54
marcf
2.5L
Car: 2005 Impreza RS wagon
Fav Mod: Swaybars
Noob question: how does the trade off between higher comp/low boost and low comp/high boost work?
is it something like low end or high end power?
The only issue I have noticed was during hard cornering with 1/4 tank of fuel, the fuel sloshes away from the pick up and pump runs dry. This will be normal for this model car and is something people need to keep an eye on if driving the car hard.
Very true, i get this when i've been pushing the car hard, more noticable with right hand turns on low fuel
i've even noticed it with almost 1/2 a tank, so i think our tanks need more baffles
marcf is offline   Reply With Quote
Old 12-27-2008, 02:30 AM   #55
DunDunSkeert
Fav Mod: 24mm adj. rsb
Trader Rating: (13)
Awesome!!
DunDunSkeert is offline   Reply With Quote
Old 12-27-2008, 10:22 PM   #56
Circaisdashiat
Circaisdashiat's Avatar
Fav Mod: non limp mode
Trader Rating: (16)
This is a great option for RS guys!
Look at the size of that thing! its soo much smaller compared to other SC's i have seen before.
high compression lagless boost. Sounds awesome to me!
Arizona All Wheel Drive - AZAWD
Circaisdashiat is offline   Reply With Quote
Old 12-28-2008, 05:53 AM   #57
02RS_keithie
tradewind do you have any numbers on the 6.2 psi intercooled kit yet? and / or maybe a dyno video?
02RS_keithie is offline   Reply With Quote
Old 12-28-2008, 06:38 AM   #58
ElvisC
2.7L
Technically High Compression motors can take boost but you will need high octane fuel to prevent detonation.
Using low compression is basically a buffer, so you can run pump gas (92+) and get the most HP out of it before you experience any kind of knock.
Old 12-28-2008, 09:47 AM   #59
bue car
#32
bue car's Avatar
Fav Mod: Which car?
Trader Rating: (174)
thanks elvis... i was curious too
Save RS25! Say no to XenForo
bue car is offline   Reply With Quote
Old 12-28-2008, 09:55 AM   #60
legacygt2001
1.8L
Car: 01 legacy
Fav Mod: randomtech cat, delta cam
trade, im kinda worried about added stress to the crankshaft
legacygt2001 is offline   Reply With Quote
