iWire Intercooler Splitters with Water Spray Nozzle Mounting Points - Page 6 - Subaru Impreza GC8 & RS Forum & Community: RS25.com
Old 06-23-2017, 10:04 AM   #51
AcquaCow
Ex-Mooderator
AcquaCow's Avatar
Car: 2001 RSTi, 2011 WRX Hatch
Fav Mod: Koni/Gymkhana suspension.
Trader Rating: (11)
Hmm, didn't see any email updates, will have to dig for it. Else, acquacow at hotmail.
Sent from my XT1650 using Tapatalk
●●● Threads of note: Bumpstops vs. lowering springssub $1000 Koni + Gymkhana buildD_rex bump extender mod
I had to rebuild my gallery, so if any of these photos don't relate to the post, please link me to the post so I can fix it. Thanks. ●
AcquaCow is offline   Reply With Quote
Old 06-23-2017, 10:06 AM   #52
IWire
Premium Vendor
IWire's Avatar
Fav Mod: Swap
Trader Rating: (23)
Yep we have that in there. It'ls probably in the spam box. Shoot me an email if you can't find it. You've missed out on some ones.
iWire Subaru Wiring Services
949-510-8278
www.iwireservices.com
IWire is offline   Reply With Quote
Old 06-29-2017, 04:54 PM   #53
Kaos22B
2.7L
Car: 1999 2.5RS
I got mine....
Kaos22B is offline   Reply With Quote
Old 07-11-2017, 06:32 AM   #54
fastfalcon94
2.7L
Trader Rating: (15)
Mine came yesterday. I haven't fully installed it, but I set it in place to snap some pictures. First impressions:
- Seems like it was built well. Fits right inside the intercooler and the holes for the shroud line up with my hood.
- It makes me realize how close my bov must have been to my hood as the shroud sits right over my turbosmart bov. Hopefully it won't rattle against it, but I'm sure I could modify it somehow if it does.
- The design in an inner piece stuck inside an outer piece. They are held together with 4 screw bolts in the corner. I am going to tack the pieces together in a few spots just to strengthen it some and to prevent any vibrations/rattle.
- I run the bakemono scoop so I bought this assuming I'd have to modify the center divider to be slightly taller. However it looks to be just about dead center with the height of my scoop. So I'm going to leave that is which is a plus.
I'll work on it getting it fully installed later this week. The underside of my bakemono scoop needs some fiberglass work and sanding to make it more oem like. So far I'm very happy with this. I think your next projects should be a plug and play abs delete kit, and a plug and play IC sprayer kit
- Charlie
My Suby Build
fastfalcon94 is offline   Reply With Quote
Old 07-11-2017, 07:08 AM   #55
flip998
1.8L
Thanks for the 1st impression and pics!
flip998 is offline   Reply With Quote
Old 07-11-2017, 08:43 AM   #56
IWire
Premium Vendor
IWire's Avatar
Fav Mod: Swap
Trader Rating: (23)
- Charlie
Thanks for posting this! Glad you like it. In reference to the tacking it together, you'll find that once the splitter is bolted to the hood it pulls everything together. We did a bunch of testing and did not hear any rattling but if you want to tack it and have the capabilities go for it!
We are working on an IC sprayer kit, just need to find some more OEM looking parts. Next two adapters are likely a proper GR TMIC bracket for the passenger's side and a power steering reservoir bracket.
949-510-8278
Old 07-12-2017, 09:59 AM   #57
AcquaCow
Ex-Mooderator
AcquaCow's Avatar
Trader Rating: (11)
I've got mine as well, just have to wait for the new nozzles to show up so that I can port my IC spray over to it.
Old 07-12-2017, 10:23 AM   #58
crazycam31
1.8L
Has anyone tried this with an aftermarket intercooler? I have a spearco and would like to get some sort of splitter set up.
crazycam31 is offline   Reply With Quote
Old 07-12-2017, 11:06 AM   #59
IWire
Premium Vendor
IWire's Avatar
Fav Mod: Swap
Trader Rating: (23)
Excellent!
We have not but looking for people to give it a shot. The concern is always that the aftermarket ones are bar and plate so they may stick up a little too high. However the metal fins that come down could be trimmed down to match and then install the rubber gasket.
New updated thread can be found here - https://www.rs25.com/forums/f14/t2307...eza-hoods.html
949-510-8278
Old 02-08-2018, 12:57 PM   #60
MilesToEmpty
MilesToEmpty's Avatar
Fav Mod: RSTI
Trader Rating: (23)
Has anyone confirmed fitment on a v7/8 JDM TMIC? I know the v7 is a bit larger then the v8.
Dog Dad of Three rescues! Zoe, Jake, and Tex - Golden Retrievers
MilesToEmpty is offline   Reply With Quote
