How To Swap To Flat Fuel Door? - Subaru Impreza GC8 & RS Forum & Community: RS25.com
Old 05-14-2019, 07:19 AM   #1
cmennens
1.8L
Default How To Swap To Flat Fuel Door?
Purchased the kit with all genuine subaru parts to swap my flip open fuel door to a flat fuel door but not sure how the cables and everything is ran? Is there an online reference?
I searched and found an old NASIOC thread from 01'. Didn't have anything helpful.
Appreciate any advice or reference...
cmennens is offline   Reply With Quote
Old 05-14-2019, 08:15 AM   #2
crazyskiier3989
2.7L
Fav Mod: KYB AGX w/ Ground Control
Trader Rating: (3)
In my outback sport I pretty much had to take out most of the driver side and rear interior. if You are doing it in a sedan or coupe I would assume it will be a little more difficult just because the c pillar and rear shelf will be in the way. But once all the interior bits, driver seat, rear seats, driver side (front and rear) trim pieces and rear fuel side trim pieces are removed mounting the cable was pretty intuitive. There were a few open clips next to some hard lines and other cables.
Hopefully that gets you a start.
Turning lemonade into lemons since 1989
crazyskiier3989 is offline   Reply With Quote
Old 05-14-2019, 09:45 AM   #3
Jack_Stalk
www.jackstalk.com
Jack_Stalk's Avatar
Trader Rating: (47)
From the factory the cable runs from the driver door sill under the rear seat and out toward the trunk area. The door itself is like 2 10mm bolts and super easy to remove. I personslly prefer the stock 98-01 ridged fuel door because its less moving parts and less hassle to have to flip a level every time you get gas.
Jack_Stalk is offline   Reply With Quote
Old 05-14-2019, 12:50 PM   #4
cmennens
1.8L
I had someone pour something in my tank last month. I could care less about convenience.
Old 05-14-2019, 12:51 PM   #5
Jack_Stalk
www.jackstalk.com
Jack_Stalk's Avatar
Trader Rating: (47)
Locking gas cap
Similar Threads
Thread Thread Starter Forum Replies Last Post
My Swap Story: 99 RS > 07 WRX av3ng3r Swaps/conversions 5 09-14-2012 08:04 PM
FS (USA,PA): Sedan/Coupe Flat Fuel Door Kit Ej22SubieRoo Exterior Parts For Sale 2 08-17-2011 08:17 AM
FS (USA,OR): 93-01 Flat fuel door set WOW mrpersonality Exterior Parts For Sale 6 08-27-2010 10:39 AM
OBDII Generic Codes crashingsucks9 Troubleshooting 5 12-07-2009 10:23 PM
